For Sale. Aluminum Warford case
Topic author - Posts: 1411
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Here is a bare aluminum Warford six speed transmission case. It has a “bite” out of the input flange. Otherwise is in good shape. I’m listing this because there are many of these out there that are in far worse condition (such as badly cracked cases) and this could be an easy repair for a qualified machinist. (I’m thinking a steel back-up flange and studs or longer bolts on the bottom). Make me an offer. I’ll ship anywhere in the USA for cost. It’s pretty light so shouldn’t be bad. Email if you want it. Please don’t post here or send a pm. Thanks!
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: For Sale. Aluminum Warford case
Hi Adam. Do you have the broken piece?
- First Name: Adam
- MTFCI Number: 1
Last chance if anyone wants it. $30 will buy it, which means it would arrive at your door for less than $50 bucks... If there are no takers in the next day or so it’s going to be machined in half the long way and made into a nice wall-hanging display piece for my shop. There would then be an opportunity for someone to buy the back side for half price.
- First Name: Greg
- Last Name: Popove
Someone could fill it in with aluminum weld and then grind it back to look original.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Done many of them worst than that one!
Just Saying
Just Saying
- First Name: craig
- Last Name: leach
Adam I'll take it for that, I have a case that' s in worse shape I can take the hole flange off of if needed. Just out of curiosity how much to repair Hank?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Normally around $80.00 plus shipping.
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
- MTFCA Number: 50618
Craig,Craig Leach wrote: ↑Sun Nov 08, 2020 11:39 amAdam I'll take it for that, I have a case that' s in worse shape I can take the hole flange off of if needed. Just out of curiosity how much to repair Hank?
I have a set of low speed gears to get you rolling if you want to piece the granny together.
Brad.
- First Name: Terry
- Last Name: Loftus
- * REQUIRED* Type and Year of Model Ts owned: 26 Speedster
- MTFCA Number: 7379
Hello Brad,
On your offer for a set of gears. It appears you are offering one gear that slides on the output shaft and another gear that presses onto the counter shaft. On the early Warfords the counter shaft diameter was smaller than the later Warfords, so the ID of the gear that presses onto the counter shaft is important. I addition the under drive gears for the aluminum Warford are a different ratio and thus tooth count than the cast iron Warford. As I recall there is only one tooth difference. I suggest listing the tooth count on both gears and the ID of the cluster gear.
Thank you,
Terry
Thank you,
Terry
- First Name: craig
- Last Name: leach
Thanks Brad,
I do have a complete trans. but the case has been broken in half, who ever tried to weld it never learned how to weld aluminum, the weld is so porous
that gear oil leaks threw it making it almost impossible to to repair. If the weld is that porous I dought it is very strong. so I have been keeping an eye out for another case to put the gears in. When I go to assemble the trans. I will assess the gears again if they are not as good as I remember ( its been over two years since I looked at them last ) I'll contact you.
Thanks again. Craig
Thanks again. Craig
