Anyone have some used valves?
Topic author - Posts: 1011
- Last Name: Osterman
I have a spare 1923 engine on a work stand. The pistons, crank bearings and cam look good. I’d just like to get it running just for fun this winter. It currently has the old two part valves so I’m looking for some modern valves that have been pulled from an engine that was rebuilt. Would like to find all intake valves if possible. Anyone have a bucket of valves after rebuilding a couple of engines?
- First Name: Ryan
- Last Name: Snellen
- * REQUIRED* Type and Year of Model Ts owned: 1912, 1919, 20's FrankenT
Re: Anyone have some used valves?
What size valve stem Mark?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Might have some too if Ryan does not have.
Just checked, have a set of stock standard size, believe to be stainless steel.
- Last Name: Hatch
- MTFCA Number: 49974
By modern do mean T valves that take the pin?
Or modern like Ford 351 exhaust valves?
Hi all. I’m looking for some standard stem size and the traditional type that take a pin. Just don’t want to use the two piece size that were in the engine.
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
I have a few sets of new valves that I bought from Specialized Antique Auto Parts In Houston in 1983 if you or anyone else is interested.
Ken Buhler
Ken Buhler
Work honestly
Stay true to your word
Get the job done right
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- MTFCA Number: 9495
- MTFCI Number: 9495
- Board Member Since: 2013
I have a lot of New Old Stock valve that are micked at .309 and .310 with the hole for the pin at the bottom. I have about 10 sets of these valves. I,m not sure what a price for them should be so make an offer that you think is fair. Tom 503-644-9374 These came out of a Ford store in Spokane Wa an Ritzville Wa. Some valve have the two holes in the valve top for the valve grinder with the two pin drive.
