FS- 1926 Coupe Fenders, Aprons, and Running Boards
msaggese
First Name: Michael
Last Name: Saggese
Post by msaggese » Thu Dec 03, 2020 3:40 pm
Selling a set of original steel 1926 Coupe fenders, running boards, aprons, and running board brackets
These came off a car built in November of 1925.
These are in somewhat rough shape, early restoration in the 1960's uhsed some brazing to fix typical crack spots.
I am including some original patch panels cut from other fenders which should be enough to cut out the brazing. One of the inner supports for the front fenders is removed and cut off.
I have already done some work to these fenders to repair some dents, dings, and cracks, especially the rears.
Free if you pick up locally, located in Vista, CA 92081.
Photos here:
https://imgur.com/a/9cg799O
msaggese
First Name: Michael
Last Name: Saggese
Re: FS- 1926 Coupe Fenders, Aprons, and Running Boards
Post by msaggese » Sun Sep 12, 2021 4:06 pm
Bump- still have the fenders. If you want them you can have them. Located in Vista.
ITDave
First Name: David
Last Name: Flowers
Post by ITDave » Tue Sep 14, 2021 1:56 pm
What are you asking for these parts? Will they fit a 27 Coupe?
ITDave
First Name: David
Last Name: Flowers
Post by ITDave » Tue Sep 21, 2021 4:37 pm
Are they still available? I'll pick them up tomorrow.
