Selling a set of original steel 1926 Coupe fenders, running boards, aprons, and running board brackets
These came off a car built in November of 1925.
These are in somewhat rough shape, early restoration in the 1960's uhsed some brazing to fix typical crack spots.
I am including some original patch panels cut from other fenders which should be enough to cut out the brazing. One of the inner supports for the front fenders is removed and cut off.
I have already done some work to these fenders to repair some dents, dings, and cracks, especially the rears.
Free if you pick up locally, located in Vista, CA 92081.
Photos here:
https://imgur.com/a/9cg799O
FS- 1926 Coupe Fenders, Aprons, and Running Boards
Topic author - Posts: 7
- First Name: Michael
- Last Name: Saggese
Re: FS- 1926 Coupe Fenders, Aprons, and Running Boards
Bump- still have the fenders. If you want them you can have them. Located in Vista.
- First Name: David
- Last Name: Flowers
What are you asking for these parts? Will they fit a 27 Coupe?
- First Name: David
Are they still available? I'll pick them up tomorrow.
