Custom Spiral Cut Ring and Pinion Gear on EBAY
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sat Dec 05, 2020 12:41 am
I have no connection with this item, except that I have bought from the seller several times. He is selling a custom made spiral cut ring and pinion gear for a Model T, EBAY # 254796507787. He told me that he is selling it for a friend who is in poor health and can't finish it. (apparently his friend is a machinist). By my count it is a 9-34 tooth set that figures out to a 3.77 ratio. He said the pinion gear needs finishing. He must be talking about the tapered bore on the inside of the gear where it fits on the end of the driveshaft, as the teeth look OK. It is listed at $99.99 or Best Offer. He made me a Heck of an offer if I was interested, but I told him I wasn't a machinist and wasn't interested. If any of you machinists out there are interested, contact me and I'll tell you what he said he'd sell it to me for.
Last Name: Gregush
MTFCA Number: 52564
Re: Custom Spiral Cut Ring and Pinion Gear on EBAY
Post by Mark Gregush » Sat Dec 05, 2020 1:51 am
1920 Dodge touring
It's Bill
First Name: Bill
Last Name: Hoffer
MTFCA Number: 32571
MTFCI Number: 24364
Post by It's Bill » Sat Dec 05, 2020 10:05 am
Does anyone know if spiral cut gears would have an adverse effect on braking? Mushy pedal, slowed reaction time, and such like? Cheers, Bill
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Dec 05, 2020 10:27 am
I came up with a set of these gears years ago... was told they were 490 Chebby, but I have never attempted to confirm. I have never tried to assemble into a Ford either...
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sat Dec 05, 2020 11:40 am
490 gears are hard to find anyway, if that is what it is. There has been talk in the past on the Chevrolet boards about using a Model T ring gear as a replacement. I think the Ford ring gear may be a direct bolt on but not sure about the pinion gear.
1920 Dodge touring
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sat Dec 05, 2020 12:19 pm
UPDATE: A check on EBAY, minutes ago, revealed that the seller has marked them "out of stock" so they are no longer available. The seller did tell me that all the ring gear holes lined up with the holes on a T differential. T. Woods
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Dec 05, 2020 12:40 pm
Yes, the offered set is stock 490 Chevrolet, yes the bolt pattern to the differential is identical to the Model T Ford.
No, there is no difference in braking just less noise!
This is an original aftermarket spiral gear set for a Model T Ford.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sat Dec 05, 2020 12:56 pm
Thanks for posting, Layden.
John Warren
Last Name: Warren
Post by John Warren » Sat Dec 05, 2020 11:27 pm
Layden, is this set for sale? I am looking for something stronger than the T
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
* REQUIRED* Type and Year of Model Ts owned: 26 coupe and 23 Runabout
Post by Stephen_heatherly » Sun Dec 06, 2020 9:49 am
I don't understand how these could be used in a T rear axle anyway. The shape of the gear teeth would try to pull the pinion inward into the axle housing under braking and quickly wear out the thrust flange on the drive shaft bushing behind the u joint. The drive shaft assembly is only designed to take thrust in on direction.
Stephen
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
MTFCA Number: 11598
Post by kmatt2 » Sun Dec 06, 2020 1:34 pm
Yes the drive shaft thrust would be a problem with the stock Ford system. The Chevy 490 used double taper bearings at the pinion gear, like the 1928 Model A and later Ford rear ends. Back in the day they used a modified Ford drive shaft pinion spool with two tapered bearings. Today we have Fun Products drive shaft bearings which should take care of the thrust problem.
