FS-CAST ALUM FINNED 3 AND 4 DIP OIL SUMP CASTINGS
Topic author - Posts: 1190
- First Name: DAN
- Last Name: MCEACHERN
THESE CASTINGS ARE 356 T6 ALUMINUM AND WILL FIT 3 AND 4 DIP OIL PANS DEPENDING ON HOW YOU DRILL THEM. On a 4 dip pan, the sump will only cover the 1st 3 dips. Provision inside to attach an oil baffle plate and there are thick side pads on each side for tapped holes for oil lines, or just use for extra oil capacity with a splash lubricated engine.
$125.00 each plus UPS shipping at cost. dmcgearsatyahoodotcom or PM me. Payment by PP or your choice of check or MO.
Last edited by Dan McEachern on Thu Dec 17, 2020 11:50 pm, edited 1 time in total.
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
- MTFCA Number: 50661
Re: FS-CAST ALUM FINNED 3 AND 4 DIP OIL SUMP CASTINGS
will take it need full amount i can pay you to day through zelle
- First Name: DAN
Rich- e-mail sent. thank you. One casting sold, I have a few more if anyone is interested.
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
Good price on a high quality casting. If I was in the need for one I'd jump on it. Finding a good older casting is somewhat difficult and when you do they've often been used and abused.
- First Name: DAN
I still have a few of these available.
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
- MTFCA Number: 50484
- MTFCI Number: 24737
Dan
Does this require spacer plate, and is there any provision for scoup on splash engine with A crank ?
- First Name: Rich
also ,is there space for wish bone clearance
Thanks Rich
Thanks Rich
- Last Name: Kemp
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT Tow Truck
- MTFCA Number: 49768
HI Dan, I would like one. Rich
- First Name: DAN
Yes, the rear of the sump will clear a stock wishbone.
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
Dan: Hi From Iowa! I would like one of the pans if available? Thanks John
- First Name: Rich
Dan
2nd email sent
Rich 561 262 0393
2nd email sent
Rich 561 262 0393
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- MTFCA Number: 9495
- MTFCI Number: 9495
- Board Member Since: 2013
Dan, I hope you have me on your list for a four dip deep sump pan. I need one for my grandson engine that I' working on. Tom
- First Name: Rich
Dan
Thanks for email reply, If used on splash engine with out anything to circulate oil from sump then it wouldn't serve much value, other than more oil capacity,
Am I correct in my thinking ? better heat transfer with pump to circulate oil.
- First Name: DAN
On a splash engine most use an accessory outside oil line like a Ford Faithfull or a hogshead oil line like the one Texas T Parts offers. The extra oil goes to the front of the engine and excess drains thru the dip tray via standoffs into the sump, returning to the flywheel area via a balance pipe/hose to the transmission area.
- First Name: DAN
Tom- PM sent. Dan
- First Name: Rich
Dan,
Please give more info/ detail about" standoff's"and how to incorporate balance pipe/hose Thanks
P M sent Rich J
P M sent Rich J
Dan: Hi From Iowa1 I have not heard back to see if I can get one of the pans? Let me know? Thanks John
- First Name: DAN
John- PM sent.
Last edited by Dan McEachern on Sun Mar 14, 2021 12:25 pm, edited 1 time in total.
- First Name: Rich
Awaiting reply.
- First Name: Lester
- Last Name: Husted
- * REQUIRED* Type and Year of Model Ts owned: 20
I will take one for a 4 dip pan. There is no cell phone service for the last 3 weeks to your place. All circuits are busy, try again later. Give me a call
Mike Husted 208-520 4892 Thanks
- First Name: DAN
All- I've been cleaned out of sump castings for the moment. Rich J. will get the last one. I've had these sitting on the shelf for over two years and thought I would sell a few. The pattern is back at the foundry but I don't have pricing. Most likely the price will increase, as I've been getting significant casting cost increases for the past 6 months. Please send me a PM here or an e-mail to dmcgearsatyahoodotcom if you want a sump casting.
John- you are on my list already. thanks all
- First Name: Rich
Dan
Sent second email
Not urgent don't know if you saw last one.
Thanks Rich J
Sent second email
Thanks Rich J
- First Name: Rich
Dan
I'm going to be in south California in June
possibly we could cross paths.
- First Name: DAN
Hello All- I have more sump castings available on a limited basis, as there were a few folks that did not get one when I 1st posted these. There was a substantial price increase at the foundry as I expected there would be. The new price is $175.00 each plus UPS shipping. If you have interest you can PM me or send an email to :dmcgearsatyahoo.com.
Thanks, Dan
Thanks, Dan
- First Name: DAN
Two sump castings are spoken for.
