Would like to purchase a nice rear taper leaf spring.
Jonathan Bodine
Rear Taper Leaf Spring
- First Name: William
- Last Name: Goble
- MTFCA Number: 31190
- MTFCI Number: 24534
Re: Rear Taper Leaf Spring
There are two types of tapered rear springs . Early with out oiler holes at the shackles and later with oil holes . Does it matter to you .
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Whatcha working on Jethro??
I might have one, I'll have to look.
- MTFCA Number: 14972
- MTFCI Number: 15411
I have several but Stan's ALOT closer !
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Re: WTB Rear Taper Leaf Spring
Jonathan, It is more helpful if you state your focus in the title. For practice, you can go to the top right corner of your post to the pencil. It will open and enable you to change what you have written. Then change the title to WTB taper leaf rear spring.
Then we know what it's about.
Ken
Work honestly
Stay true to your word
Get the job done right
Topic author - Posts: 39
- First Name: Jonathan
- Last Name: Bodine
- MTFCA Number: 4006
Thanks for the replies. I found that for which I was looking.
Best regards,
Jonathan Bodine
Best regards,
Jonathan Bodine
