Wanted: Four Original Knurled Nuts For ignition Wires
Topic author - Posts: 339
- First Name: Gene
- Last Name: Emering
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
- MTFCA Number: 49671
I would like to find four original knurled nuts that hold the ignition wires to the spark plugs on my '13 Touring.
I have reproductions so do not need repros.
Thanks,
Gene
Thanks,
Gene
Gene Emering
Newton, New Jersey
Newton, New Jersey
Re: Wanted: Four Original Knurled Nuts For ignition Wires
I have seen so many different patterns of knurled spark plug nuts with an xxxx pattern I'm not sure what original is but an old ad looks like MAc'S.
So is what is correct? By the way many old ads show the nut that way.
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
Gene, Some spark plugs have Metric threads & some are SAE. It depends on your spark plugs. George
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Yeh the one in Mac's ad is nowhere near the same!
- First Name: Gene
I’ve attached a few photos of the knurled nuts that are on my car.
I believe that the ChampionX plugs I have are newer.
Gene Emering
Newton, New Jersey
Newton, New Jersey
- First Name: Gene
Here’s a photo of the Plugs
Gene Emering
Newton, New Jersey
Newton, New Jersey
- MTFCA Number: 52564
I think the slot was so you could use the Rajah type terminals that clipped on.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
If they're "newer" current Champion X, they might be metric thread - I don't believe anyone produces an "original" copy for those - I have some current repro X's & will check the thread size. If they're original or an older reproduction then these will fit - 8-32 is the original thread - I have a limited quantity.
Come to think of it Gene, I have some NOS original X's in my display case - I'll open one up !
- First Name: Gene
Thanks Steve!
Gene Emering
Newton, New Jersey
Newton, New Jersey
