SUNDAY SWAP MEET
Topic author - Posts: 3327
- Last Name: Chaffin
- MTFCA Number: 31705
SUNDAY SWAP MEET
Once again, time for the Sunday Swap Meet! Description and prices are as indicated below. Actual domestic shipping USPO Flat Rate will be an additional charge. Usually $8.50 Small Priority Flat Rate will apply. Combine items and save on shipping. Payment by PayPal (preferred) or check. Message me or call Mark Chaffin (951) 805-0928
1. Block off plate set (Starter, Generator and Bendix) $30.00 SOLD
2. Front wheel bearing set (2 inners and 2 outers R/L hand thread) $45.00 SOLD
3. Outer bearing set (R/L hand thread) $35.00 SOLD
4. Front bearing race set (inner and outer) $25.00 SOLD
5. Light sockets and thimbles (dual contact) (4) $30.00 SOLD
6. Rear axle bronze thrust washer $7.00 SOLD
7. Headlight socket thimbles NOS (5) $10.00 SOLD
8. Magneto posts (2) $10.00
9. Magneto post with outside oiler outlet (2) $10.00 SOLD
10. Spindle arm set NOS $35.00 SOLD
11. Pedal pad set $5.00 SOLD
12. Transmission band puller $10.00 SOLD
13. Early brass carburetor shut off valve $22.00 SOLD
14. Switch Assembly (Pin Style) $25.00 SOLD
15. Generator mounting bolts NOS (6) $10.00 SOLD
16. Demountable rim bolt and nuts used (32 pieces) $30.00
17. Hub bolt and nuts (40 pieces $25.00 SOLD
18. Brass valve stem, nuts and bridge washers (12 pieces) $35.00
19. Outside oiler parts $40.00 SOLD
Last edited by Mark Chaffin on Fri Feb 26, 2021 4:45 pm, edited 10 times in total.
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: SUNDAY SWAP MEET
Put my name on the brass carb. shut-off, please !
Sorry Steve. Missed it by about three minutes. Maybe next time sir! Thank you for your interest though my friend. Much appreciated.
Hi Mark
what are the valve stem numbers?
I may be interested...
NH Full Flow Float Valves
- First Name: randy
- Last Name: lee
- * REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Mark, I will take #2 and #3 will call you monday am ...thanks
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Mark, I'll take outside oiler parts, if still available.
Sorry Terry. Someone else beat you to it. Thank you for your interest!
Valve stems are off repo tubes for wood wheels. I believe the number is 383.
Thanks Mark
I'll pass
I'll pass
