Cleaner than the rusted up stuff you find on Flea Market tables. Excellent bowl, (older) modern float material which appears to have never seen fuel, good pick-up tube, good looking main jet. Cast iron throttle lever, stamped steel choke lever with good spring.
All complete with the exception of a missing venturi, but many if not most will crack upon removal anyway...due to this fact, these are needed often enough, that they are reproduced and available through vendors or other hobbiests.
Needs complete rebuild, of course (along with a new venturi)
I apologize right now for the upside down photos...it messes with my brain trying to look at it and perhaps it does you, too.
$40 plus actual postage
For Sale - Holley G, cast iron with excellent bowl
Topic author - Posts: 6435
NH Full Flow Float Valves
- First Name: Bob
- Last Name: Shirley
- MTFCA Number: 29135
Re: For Sale - Holley G, cast iron with excellent bowl
If you still got it I’ll take it, Bob at nine o3-824-1949
Bob
if you want it, it's yours
please send me an email with your zip code and I'll figure out shipping cost.
Thank you.
Thank you.
