LOOKING FOR WTB GAS TANK SEDIMENT BULB OUTLET FLANGE
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
MTFCA Number: 49646
Post by StevenS » Fri Feb 26, 2021 10:05 am
I am needing for an oval tank 1920ish, the bottom treaded flange for the sediment bulb to screw into. Mine is missing. If you have an old tank the is bad and the part is good, I would be interested in it. Especially if you can cut about 2 inches or more away from it so I can use it as a patch and have something to weld to. I then can save this tank for to be used, that is all that is wrong with it.
1924 Model T Touring
1924 Model TT Truck
1930 Model A Pheaton
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: LOOKING FOR WTB GAS TANK SEDIMENT BULB OUTLET FLANGE
Post by Henry K. Lee » Fri Feb 26, 2021 10:08 am
Let me go and check in the barn, I think I have one left!
CTLeonard
Last Name: Leonard
Post by CTLeonard » Thu Mar 04, 2021 4:29 pm
i had sent an email i have one im looking at
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Mar 04, 2021 5:55 pm
Sorry for not replying back sooner. Only had one attached to a complete tank.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Thu Mar 04, 2021 11:53 pm
Anyone know where you would find the inlet & outlet castings if one where to try making a new gas tank? Hank didn't you know the Gentleman that was making the tanks?
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Fri Mar 05, 2021 12:41 am
If you don't have to have original, they are 1/2 pipe thread. Any plumbing store has 1/2 inch pipe threaded screw plates about 3 inches in diameter.
Or find a piece of brass or copper --- which is what I would do -- 1/4 inch thick, drill and tap it 1/2 inch pipe and solder it on to the tank.
StevenS
First Name: Steven
Last Name: Sebaugh
MTFCA Number: 49646
Post by StevenS » Fri Mar 05, 2021 8:44 am
Thanks Stan
1924 Model TT Truck
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Mar 05, 2021 9:26 am
Steve I have brass bungs but they are not original but work fine.
Email is acting up, you can call me at four 2 three ate 3 seven 57O nine.
