Post
by Scott_Conger » Thu Mar 04, 2021 6:10 pm
What you'll get:
- Custom float valve installation tool (not available anywhere else)
- Full Flow Float Valve to un-strangle your NH and finally make it run correctly on hills (not available anywhere else)
- Lead seal to fully seal the valve/body interface - stop relying on the too-hard fiber seals which never seal properly (not available anywhere else)
PLUS:
2 Brand New USA made High Speed Steel taps:
- to clean out the adjustment needle threads plus the Full Flow Float Valve threads (1st tap)
- to clean out the Jet threads (2nd tap).
If you're going to do the job, do it right, and use the best parts and tools possible.
Everything listed for $83 plus $8 shipping: $91 total
Email only please, no PM's. I may not see replies. Thank You.
Why do Full Flow Float valves work so well? They have the CORRECT DIAMETER throughput (among other things!). What everyone else sells is on the left, what I sell is on the right. Why settle for incorrectly made ersatz, that will starve your car of fuel at the
worst possible time?
What you'll receive: 1 Ultimate NH carb upgrade Kit, PLUS 2 correct, USA made High Speed Steel taps (not carbon steel junk)
NH Full Flow Float Valves
Post
by Scott_Conger » Sun Mar 07, 2021 10:45 am
Back to the top
RLMills
- Last Name: Mills
Post
by RLMills » Sun Mar 07, 2021 5:06 pm
Scott,
I want to purchase The Ultimate NH carb upgrade kit plus tapes.
Can I pay with a debit card?
What is my next step?
Thank you,
Larry Mills
477 East Maitland Ln
New Castle. PA 16105
Contact email at
eksflynn@gmail.com
Or text or call: 724-657-7461
Walt
- First Name: Walter
- Last Name: Stone
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster pickup
- MTFCI Number: 14045
Post
by Walt » Wed Mar 17, 2021 11:59 am
Scott,
I would like to buy one of your NH kits
Walter Stone
whstone@gmail.com
3801 Mount Airy Drive
Mount Airy, MD 21771
Post
by Scott_Conger » Thu Mar 18, 2021 1:35 pm
I am down to just a few valves left to make up these kits.
I will be making more, later spring or early summer, but if you plan to tour hills or open highways any time in the near future, and want one for Spring Touring. Act now or wait for the summer.
Thank you and Happy Touring.
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
Post
by BE_ZERO_BE » Thu Mar 18, 2021 4:46 pm
Scott,
I will take the ultimate kit.
email sent
Respectfully Submitted,
Be_Zero_Be
- First Name: Dallas
- Last Name: Landers
- MTFCA Number: 49995
Post
by Dallas Landers » Thu Mar 18, 2021 7:51 pm
Hey Scott, I'm almost to Chickasha but put my name down. I will contact you when I get home.
tmagill
- Last Name: Magill
- MTFCA Number: 4444
Post
by tmagill » Fri Mar 19, 2021 5:56 am
Hey Scott, do you sell just the taps? I already have your float valve kits. Tim
Post
by Dallas Landers » Sat Mar 27, 2021 5:02 pm
Bump and I sent you an email Scott.
Dallas
Mighty1924
- First Name: Rick
- Last Name: Shaw
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
- MTFCA Number: 31541
- MTFCI Number: 24327
Post
by Mighty1924 » Sat Mar 27, 2021 5:40 pm
Scott
Sent you a email about getting a couple float valves and washers
Rick S.
- Last Name: Hatch
- MTFCA Number: 49974
Post
by Dan Hatch » Sat Mar 27, 2021 6:18 pm
If you are running a NH you need one of these.
Question Scott. Will these also work in a Vaporizer?
Thanks for making them. Dan
Post
by Scott_Conger » Sat Mar 27, 2021 8:30 pm
Dan
they will indeed work in a vaporizer
Bob in ohio
- First Name: Bob
- Last Name: Gairing
Post
by Bob in ohio » Sat Mar 27, 2021 11:03 pm
Hello Scott - I would like to buy one of your upgrade kits plus an additional valve if possible. Please advise total cost.
