WTB 1924 Engine
Topic author - Posts: 451
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
WTB 1924 Engine
This might be a long shot, but I would like to find a 1924 good rebuildable engine or block bearing the serial number as close to 9,495,000 (March 11) as possible. That was approximately the number of my 1924 Touring originally but since had been changed out due to a cracked block 30 years ago. Please let me know what you have and if you can take it to Chickasaw as I have a friend of mine who can pick it up for me. Even if I can find one made in March (9,427,000 to 9,622,000) I'd be a happy camper.
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Re: WTB 1924 Engine
Thirty years ago when you changed out the cracked block engine did you keep the old block and does that number match your current VIN number ? In 1923 Ford stopped using casting dates and by late 1923 stopped using the cast Ford script in the block. The only way to tell a 1924 or 1925 block, (pre 1926 type) is by engine number. If your goal is to get a block close to the old engine number it would be better to find the best condition 1924 - 1925 block you can to start your rebuild with and then remumber it to your number, you will be putting a lot of money into the rebuild. Even Ford back in the day sold unnumbered replacement blocks that were to get the original number they replaced.
- Last Name: McClelland
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Mother-n-law roadster, 1919 Coupe, 1920 Depothack, 1922 Centerdoor, 1923 Roadster, 1923 Speedster, 1924 TT Truck,
Re: WTB 1924 Engine
I’ve got a 9772446 but that maybe too far off from where you want to be.
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: WTB 1924 Engine
Some time in 24 they quit adding FORD Made in USA on the side of blocks as 25's do not have that.
- First Name: Joe
- Last Name: Bell
Re: WTB 1924 Engine
Also in 23-4 the round dial was still visible where they use to have day month and year on so there is special dates for this block.
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
- MTFCA Number: 50484
- MTFCI Number: 24737
Re: WTB 1924 Engine
Email sent
- Last Name: Snell
Re: WTB 1924 Engine
Hi Rich, Will call you tomorrow to discuss, yours is April 2.
- First Name: Jerome
- Last Name: Hoffman
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 Roadster, 1923 Speedster, 1923 Racer, 1921 TT Wood Cab
- MTFCA Number: 215
Re: WTB 1924 Engine
I have a couple but will need to check the numbers, will let you know on wed. J
model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
- Last Name: Snell
Re: WTB 1924 Engine
Thanks Jerome, are you going to Chickasaw?
- Last Name: House
- MTFCA Number: 115
Re: WTB 1924 Engine
Nope.... I looked.....One 1918 engine, two calendar year 19/model year 1920, a serial 3,933,901; a serial # 7,474,130 and a serial# 11,801,993...
I don’t know why I turned out this way. My parents were decent people.
- Last Name: Snell
Re: WTB 1924 Engine
Hi George. Does your serial number 11,801,993 happen to have the FORD script on the driver side of the block? Just curious as we are having a debate when that was stopped. Thanks
- First Name: Dennis
- Last Name: Michaud
- * REQUIRED* Type and Year of Model Ts owned: 1909 roadster, 1911 mother-in-law, 1912 torpedo, 1912 touring
- Board Member Since: 2010
Re: WTB 1924 Engine
I have a 1923-5 rebuilt short block that I can stamp with your serial # $2700 plus shipping, Give me a call Dennis 401-932-3191
- Last Name: Snell
Re: WTB 1924 Engine
Hi Dennis
Does your block have the Ford script on the side?
