FS SUNDAY SWAP MEET
Topic author - Posts: 3347
- Last Name: Chaffin
- MTFCA Number: 31705
FS SUNDAY SWAP MEET
Once again it is time for the Sunday Swap Meet. This week we have an assortment of mostly new items. Prices indicated are well below retail. Items are generally shipped USPO Priority Flat Rate. Combine items and realize a savings on shipping. Payment by PayPal (preferred) or by check for those not so inclined to use PayPal. First come first serve. Message me or call Mark Chaffin (951) 805-0928. Thank you and enjoy your day!
1. Coil box porcelain tube set 09-13 (Glazed) $10.00 SOLD
2. Gas line inlet and pack nuts $10.00 SOLD
3. Water pump packing (3 sets) $5.00 SOLD
4. Starter mounting bolt set $1.00 SOLD
5. Starter mounting bolt set $1.00
6. Front radius rod mounting set $4.00 SOLD
7. Brake rod clevises (3) $10.00 SOLD
8. Driveshaft roller bearing inner sleeve $10.00 SOLD
9. Generator third brush and term nut wrench Ford script $10.00
10. Generator third brush wrench Ford Script 5-Z245-1 $10.00 SOLD
11. Generator third brush wrench Ford script 5-Z-249 $10.00
12. Battery clamp set $5.00 SOLD
13. Curtain hook sets (2) $4.00 SOLD
14. Axle shaft keys (4) $2.00 SOLD
15. Crank pulley pins for late pulley (3) $2.00
16. Cast Iron muffler mounting bolt and nut set $4.00 SOLD
17. Emergency brake shoe mounting bolt and nut set (09-25) $5.00 SOLD
18. Oil Pet cocks brass (2) $10.00 SOLD
19. Carburetor choke bell crank NOS $5.00 SOLD
20. Wire loom clips (7) $5.00 SOLD
21. Battery clamp set $5.00 SOLD
22. Spare tire wire wheel security lock nut $6.00 SOLD
23. Timer shield $2.00 SOLD
24. Headlight thimble set (dual contact) 6592X 17-27 (2) $15.00 SOLD
25. Gas line to frame support clamp set (2) $2.00 SOLD
26. Front fender bracket rivet set 17-25 (2 sets) $2.00 SOLD
27. New Day timer brush assembly new $8.00 SOLD
28. Lift up oiler assortment (26 pieces) $15.00 SOLD
29. Oil lamp wick sets (4 wicks) $2.00 SOLD
30. Front radius rod mounting set $4.00
31. Castle nuts (8) $5.00 SOLD
32. Oil sight gauge with drain cock $10.00 SOLD
33. Camshaft oil seals (2) $5.00 SOLD
Last edited by Mark Chaffin on Mon Apr 12, 2021 8:45 pm, edited 18 times in total.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
Re: FS SUNDAY SWAP MEET
Mark, I sent you a text with the numbers I would like to buy. Darryl Bobzin
Received. Thanks Darryl!
- First Name: Joe
- Last Name: Voller
- * REQUIRED* Type and Year of Model Ts owned: 1924 pickup 1922 centerdoor
- MTFCA Number: 49985
mark , I sent a list of parts i wopuld like . Joe Voller
- First Name: jay
- Last Name: bolante
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
- MTFCA Number: 31221
Mark. I would like to buy number 27, new day timer brush. Thank you..
- First Name: Eric
- Last Name: Keenan
- * REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
Hi mark I would like #15 and #19 thank you Erick
- First Name: Shannon
- Last Name: Helm
Mark,
I sent you a PM and text. Thanks— Shannon
Updated. Only a few items remaining!
- First Name: JOHN
- Last Name: YERGLER
- * REQUIRED* Type and Year of Model Ts owned: 1921 Model TT
Hi Mark, if #33 and #21 are still available, I will take them. I will be driving to the shop later this week to pick up other parts so I can just pick up and pay then if that works for you.
Thanks,
John Yergler
Thanks,
John Yergler
#21 and #33 sold to John. Thanks John!
