Stevens Tool Cutting tools at Chickasha
Topic author - Posts: 4110
- Last Name: Hatch
- MTFCA Number: 49974
Guys: Will have some of my Stevens Front axle tool reamers and inserts at Chickasha. South Building EAST BACK corner. Limited number of reamers and inserts. Get them quick if you need them. Dan
- Attachments
- stevens 151.9.jpg (6.76 KiB) Viewed 2642 times
- stevens 151.8.jpg (8.93 KiB) Viewed 2642 times
- First Name: Paul
- Last Name: Bourgeois
- Board Member Since: 2006
Re: Stevens Tool Cutting tools at Chickasha
Dan, I'm thinking of buying the "Stevens front axle tool" from Jack Putnam, in Ohio and would like to know if you have any reamers and inserts available, and if so, price?
Thanks,PaulB
Thanks,PaulB
- Last Name: Hatch
Paul Yes I do. Tapered Reamer( Upper) $210.00 each. Reamer/Tap ( Lower) $150.00 each. Upper Inserts $3.50 each. Lower inserts $5.50 each. All plus shipping. Pm or email me for more info. Thanks, Dan
- Attachments
- address.jpg (22.77 KiB) Viewed 2449 times
I have yet to come across a T that did not need this tool used on it. Dan's product is well made, holds up well, and works like it is supposed to.
Kudos to you, Dan
Kudos to you, Dan
NH Full Flow Float Valves
