Water jacket rusted through
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Tue Mar 23, 2021 1:27 pm
The water jacket on my '21 is rusted through. Is there an acceptable way to repair them and stop the leak?
MTFCA Number: 14972
MTFCI Number: 15411
Re: Water jacket rusted through
Post by RajoRacer » Tue Mar 23, 2021 1:41 pm
Depends on where & how bad - this one didn't take !
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Tue Mar 23, 2021 4:03 pm
If you found one spot rusted thru, then there are likely to be more very thin spots. The best option will probably be replacing the block with a better one.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Mar 23, 2021 4:24 pm
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Post by Mark Gregush » Tue Mar 23, 2021 4:49 pm
AS you posted in the classifieds, maybe just change the title to looking for replacement block with 1921 casting date.
1920 Dodge touring
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Tue Mar 23, 2021 6:56 pm
Let me add that the leaks are internal, not external. The car is titled by the this engine number I would like to keep it. Also it is standard bore and crank.
Post by Allan » Tue Mar 23, 2021 8:10 pm
Chris, you can run a replacement block and keep your chosen engine number. Just remove the side water outlet and make a pattern of the outlet and the included engine number boss. Use the pattern to make a brass insert to go between the block and the water outlet. Stamp the insert with the required number. When fitting, use a heavy coat of black RTV on the engine side of the insert, and simply wipe away the excess. It will fill any discrepancy between the boss and the insert, and a coat of paint will complete the job. Nothing is ruined in this approach. You still have the original block, and the donor also remains unaltered.
I had to do this with my barn fresh buckboard, mainly because the boss was so rusted the engine number was indecipherable. To ease potential problems with the inspection station and to make their job easier, I stamped the number on the insert according to the registration certificate so they could do their checks.
Hope this helps. Allan from down under.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Mar 23, 2021 9:05 pm
Allan, he is in Cali-fruity and their DMV is not very friendly. Easier to just to re-stamp a block with period correct numbers and say nothing.
Post by Allan » Tue Mar 23, 2021 10:22 pm
Ours are just as picky Hank, despite the $60 up front fee to do the looking. What they don't know won't bother them. Just show them where the number is, volunteer nothing, and leave them to it.
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
MTFCA Number: 11598
Post by kmatt2 » Wed Mar 24, 2021 12:00 am
Have your engine rebuilder check your cleaned block. A internal water jacket rust crack may or may not be fixable. A crack into a cylinder can be sleved, a crack near a valve can be pinned and new seat. Some cracks into the valve galley can be hard to fix due to location.
If you go with a better block I wouldn't use the brass tag over the number boss. If the California CHP spots the tag and then finds a different number under it they won't be to kind and may impound your car. Better to use your number on the replacement block just like Ford would have done back in the 20's.
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Wed Mar 24, 2021 12:03 am
Obviously you have never had a serial number inspection and verification by The California Highway Patrol. Their inspectors are sharp and have all the information about a Model T, with pictures, in their cell phones.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed Mar 24, 2021 1:12 am
Look up Loc n Stitch. They are is Ca and maybe able to help you. Maybe you can fix it yourself with their help. Dan
Post by Wayne Sheldon » Wed Mar 24, 2021 3:08 am
Califunny does NOT like engine numbers! They WANT the number on the FRAME! Need I say more?
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Wed Mar 24, 2021 8:22 am
Loc n Stitch is an excellent product but won’t work on a block that is rusted thru because the material to be pinned needs to be 1/8” thick. Sometimes you can fix a freeze crack with them, but rust thru is real dicey to deal with. When you start drilling into the water jacket, you generally find metal which is a very thin layer of actual good cast iron towards the outside and a layer of brittle semi-oxidized gray to black material changing into actual rust as you get into the water jacket. You need 1/8” of good silver cast iron for the pin to hold. It’s almost impossible to find any 1/8” thick metal on a “rusted thru” T block. You could remove large areas of rust-thru back to 1/8”+ good metal, make precise-fitting patches and pin them in, but that is something that is not worth while on a ‘21 block.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Mar 24, 2021 9:02 am
Might want to try a cold solder method of penning into place. Just throwing out options.
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Wed Mar 24, 2021 11:18 am
In California you can use a private VIN verifier. They can provide paperwork that will allow you to get a "pink" only. When your ready to run the car take the :pinK' to he DMV and its a real short process to get tags.
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Wed Mar 24, 2021 12:48 pm
I find the opposite. When applying for a title for a non titled vehicle or a vehicle coming from out of state the CA DMV always refers you to the CHP for verification. I have been doing this for over 50 years. I know their system well and use it often.
