SUNDAY SWAP MEET
Topic author - Posts: 3353
- Last Name: Chaffin
- MTFCA Number: 31705
SUNDAY SWAP MEET
Good morning everyone and Happy Easter! Hope you all are doing well. This week’s Sunday Swap Meet offerings are all good new, NOS and a couple used items. Description and prices are as indicated below. In most cases, USPO Flat Rate shipping will be an additional $8.50. Payment by PayPal (preferred) or by check. Message me or call Mark Chaffin (951) 805-0928
1. Schrader style chrome valve cover set (T-1500-B) Retail $15.95 each. Get all four pieces for $35.00 SOLD
2. Engine block water jacket freeze plug set (3) new $1.00 SOLD
3. Engine pan mounting bolt set new Retail $9.95. Your price $4.00 SOLD
4. Batter clamp set new. Retail $8.50. Your price $5.00
5. Front radius rod mounting stud and nut set new. Retail $6.95. Your price $5.00 SOLD
6. Kelsey demountable rim lugs (Model K) Two lugs. No longer available $20.00SOLD
7. Kelsey demountable rim lugs (Model Firestone Rim Model K Ford) No longer available. All four $40.00 SOLD
8. Kelsey demountable rim lugs (Model C-17) No longer available. Get the pair for $25.00
9. Brass steering wheel nut new. Retail $14.95. Your price $7.00. SOLD
10. Carburetor choke rod bell crank NOS $5.00
11. Kelsey demountable rim lugs (2847B / Model C-165 for Metal Fellow Wheels) Retail $16.75 each. All five for $30.00.
12. Truck latch key new. Retail $12.95. Your price $8.00
13. Top socket saddle support ½ hole new. Retail $11.95. Your price $8.00
14. Crankshaft pulley pins (5) new. Retail price .95 each. Your price for all five $3.00 SOLD
15. Wheel dust seal new. Retail $13.95. Your price $6.00
16. Battery clamp set new. Retail $8.50. Your price $5.00
17. Brake cam set (09-25) NOS $16.00 SOLD
18. Radiator and gas tank gaskets (15) new. Retail .50 each. Get all fifteen for $4.00 SOLD
19. Valves new. Retail $9.95 each. Get two for $8.00 SOLD
20. Front fender rivet sets (17-25) new. Retail $2.25 per set. Get two sets for $3.00
21. Water outlet (17-25) new. Retail $24.50. Your price $15.00
22. Bendix drive bolt and lock washer set new. Retail $2.95. Your price $1.50 SOLD
23. Brake lever pawl and lever pins NOS $3.00
24. Starter mounting bolt and washer set new. Retail .95. Your price .50 SOLD
25. Generator third brush wrench (5-Z-349-1) NOS $10.00
26. Miscellaneous rear axle felt seals new $3.00 SOLD
27. Battery clamp set new. Retail price $8.50. Your price $5.00
28. Generator twist type oiler chrome plated new. Retail $19.95 each. Get both for $20.00
29. Battery ground strap new. Retail $15.50. Your price $10.00
30. Horn bracket (19-25) used $5.00 SOLD
31. Ruckstell axle data plate new. Retail $4.95. Your price $3.00
32. Universal joint pins (10) new $2.00 SOLD
33. Demountable wheel nuts (16 pieces) NOS. Retail $2.49 each. Get them all for $20.00 SOLD
34. Magneto posts (1 new and 1 used). Get both for $20.00
Last edited by Mark Chaffin on Mon Apr 05, 2021 11:04 am, edited 8 times in total.
- Last Name: Clements
- MTFCA Number: 49592
Re: SUNDAY SWAP MEET
Mark, I will take that #30 horn bracket and those #17 brake cams.
#17 and #30 sold to Scott. Thanks Scott!
#6, #7, #19 and #33 sold to Rich. Thanks Rich!
#1 sold to David. Thanks David!
#2, #22, #24, #26 and #32 sold to Craig. Thanks Craig!
#18 sold to Dave. Thanks Dave!
- First Name: Lester
- Last Name: Husted
- * REQUIRED* Type and Year of Model Ts owned: 20
I'll take number 3, 5, 9, 14, if available Mark thankyou Mike Husted
#3, #5, #9 and #14 sold to Mike. Thanks Mike!
Still have a few items available.
