UP FOR SALE IS THIS MODEL T FORD - OTHER MAKES BRASS ERA ORIGINAL RUNNING BOARD MOUNT SPARE TIRE CARRIER
30 1/2" WIDE
5 1/2" WIDE
EACH GROVE IS ABOUT 2 1/4" WIDE
HAS THE MOUNTING HOLE PLUS 2 DRAIN HOLES
LONG ROD TO HOLD IT TOGETHER
HAS ONE BRACKET TO GO AROUND TIRES THE OTHER CAN BE MADE EASY USING THE ONE FOR A PATTERN
VEY RARE PART DO NOT MISS OUT
COULD BE EARLY 1900'S AUTOMOBILE
100.00
SORRY MY CAPS LOCK IS STUCK ON
815-633-7244
MODELT2001@COMCAST.NET
