One item left, wonderful tire pump
Topic author - Posts: 3384
- Last Name: Morsher
Only one item left from this pile. It’s a sleeper, someone will be happy to get it. This is an original Bridgeport tire pump with a small ford script on the underside. The barrel is nickel plated brass. Some age cracks on the backside, but it will display well, and this one is rarely seen. An overnight dip in vinegar will make the nickel shine. Could be fixed to actually use, but why? Have you ever tried to use a tire pump on an old car tire. Thought not ! Great item for the late teens T model. I’ll bet you’ll be the only flivver owner with this model in your circles. This one is even harder to find than the double barrel Bridgeport or even the late 1927 pump. $75 plus the shipping cost , just yell via email if you need more info or better pics. Tmorsher@icloud.com
