Wanted good used 11 tooth pinion
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sun Apr 11, 2021 11:00 am
Looking for a good used 11 tooth pinion with no pitting, chunks missing, cracks or major wear. This is for a temporary rear end. I don't have room to tie up while I rebuild the one that is under the car (which is going to be slow process at this point) so have to be able to move/drive the car till it is done. The 2 I have now are too far gone for even temporary use.
1920 Dodge touring
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: Wanted good used 11 tooth pinion
Post by Ruxstel24 » Sun Apr 11, 2021 11:02 am
I'm sure I have a couple Mark.
I'll be over there later today and look for you.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sun Apr 11, 2021 11:09 am
Thank you.
1920 Dodge touring
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sun Apr 11, 2021 1:02 pm
Here’s two pretty good ones...$25 including shipping. I’ll send you an email Mark.
Same if anyone needs the other one.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Sun Apr 11, 2021 8:05 pm
I'll take the one on the top left in top photo. I will reply to the email. Thank you.
1920 Dodge touring
