Looking for a good used 11 tooth pinion with no pitting, chunks missing, cracks or major wear. This is for a temporary rear end. I don't have room to tie up while I rebuild the one that is under the car (which is going to be slow process at this point) so have to be able to move/drive the car till it is done. The 2 I have now are too far gone for even temporary use.
Wanted good used 11 tooth pinion
Topic author - Posts: 4956
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
1920 Dodge touring
1920 Dodge touring
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Wanted good used 11 tooth pinion
I'm sure I have a couple Mark.
I'll be over there later today and look for you.
Thank you.
1920 Dodge touring
1920 Dodge touring
- Last Name: Hanlon
Here’s two pretty good ones...$25 including shipping. I’ll send you an email Mark.
Same if anyone needs the other one.
I'll take the one on the top left in top photo. I will reply to the email. Thank you.
1920 Dodge touring
1920 Dodge touring
