early brass horn
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
early brass horn
Post by Scott Rosenthal » Sun Apr 11, 2021 11:12 am
WTB Early brass double twist horn with "scalloped style cover". Entire horn or cover with bell only. Must be restorable parts. Call 1 513 378-4235
Eric Edwards
First Name: Eric
Last Name: Edwards
* REQUIRED* Type and Year of Model Ts owned: 1909 Town Car 1912 Touring
MTFCI Number: 16
Re: early brass horn
Post by Eric Edwards » Tue Apr 13, 2021 10:00 am
I have a few reproduction double twists left but not with the scalloped screen. Eric Edwards
Scott Rosenthal
Post by Scott Rosenthal » Sat Apr 17, 2021 9:49 am
Still no activity per this request....hope someone here has this either complete or as parts. If interested in a trade, I have (2) double twist style horns with the standard bell cover and horizontal inlet...both are perfect show quality...one stamped RUBES, one with no stamping. Both are originals that I restored.
Not sure what the provenance of this style is, or precisely how long Ford was using them, although I don't believe I've seen one on a 1910 car. Never seen one that has a radial double twist tube like 1910 through 1912....all have a semi-rectangular wrap of the tube. Benson Ford has invoices showing (7) different horns having been supplied in 1909, however nothing describes exactly what the physical differences may have been. Perhaps someone here is in the know on this?
Regards,
Scott
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sat Apr 17, 2021 9:27 pm
Scott I sent you an email this morning.
Let me know if you got it.
Herb
Scott Rosenthal
Post by Scott Rosenthal » Sun Apr 18, 2021 7:02 am
Hi Herbie:
Not seeing it, but have a new computer that I'm still struggling with, so could be I don't have this dude set up correctly. I'm "srosenthal@fuse.net"
Regards,
Scott
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Sun Apr 18, 2021 10:09 am
I sent one first through the forum. Now I sent one privately.
Herb
1912touring
First Name: Michael
Last Name: Hanson
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 Touring
MTFCA Number: 30276
MTFCI Number: 23468
Board Member Since: 2011
Post by 1912touring » Sun Apr 18, 2021 2:00 pm
Hi Scott. Attached are some photos of a 1909 touring I once had that has the horn you are looking for. The car, which was restored by Marv Roth, is now owned by Russ Furstnow.
In my search for a Sears horn, I will keep my eye out for your horn.
All the best,
Mike
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Sun Apr 18, 2021 7:50 pm
Just curious, what does the Sears horn, you are looking for, look like? I assume fir a Sears car?
Last Name: Tannehill
MTFCA Number: 49460
Post by JTT3 » Sun Apr 18, 2021 8:05 pm
Side mount
Tiller mount
Scott Rosenthal
Post by Scott Rosenthal » Mon Apr 19, 2021 9:28 am
Wow Mike, that Sears pigtail horn is quite an arrangement. The scalloped horn on the 09 is the only one I've seen with the radial inlet tube...very cool, thanks for sharing these.
Regards,
Scott
Scott Rosenthal
Post by Scott Rosenthal » Wed Apr 21, 2021 6:58 am
Apologies John T. I received your Email and thought I had sent a response,, but apparently did not, so resent this AM.
Regards,
Scott
1912touring
First Name: Michael
Last Name: Hanson
MTFCA Number: 30276
MTFCI Number: 23468
Post by 1912touring » Wed Apr 28, 2021 10:11 pm
Hi Scott. Found this original photo on eBay. Looks like the horn your looking for. Mike
Scott Rosenthal
Post by Scott Rosenthal » Fri Apr 30, 2021 7:03 am
Yep, that's the one...Still looking. Attached shows the 09 style that I initially appropriated for my 09 project. It's a Concours quality restored original. I've come across (2) of the scalloped style in the last (6) months, where both had damages that I will say could not likely be restored. Someone out there has one of these....I doubt they were exclusive to Fords.
Regards,
Scott
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Fri Apr 30, 2021 8:24 am
Scott I sent you another email yesterday.
Herb
1912touring
First Name: Michael
Last Name: Hanson
MTFCA Number: 30276
MTFCI Number: 23468
Post by 1912touring » Mon May 10, 2021 10:33 pm
Hi Scott. Left you a voicemail. Please see the following listing on eBay. Good luck!
Original Double Twist Rubes Brass Automobile Horn Ford Model T
Item number:393311429252
Kind regards,
Mike Hanson
Scott Rosenthal
Post by Scott Rosenthal » Tue May 11, 2021 10:54 am
Hello Mike:
Got your message and will watch this auction. I hope you were the buyer who snagged the recent Sears Pigtail horn I saw on EBAY? Looks like a good part less missing only the mounting bracket.
Many thanks to the MTFCA Classifieds and a number of good folks here...leads and parts have netted restorable parts that may factor into a constructed horn. Still looking for a couple of minor pieces in better donor condition then I'll post photos of a finished product.
Regards,
Scott
1912touring
First Name: Michael
Last Name: Hanson
MTFCA Number: 30276
MTFCI Number: 23468
Post by 1912touring » Tue May 11, 2021 1:30 pm
Hi Scott. Wasn't me on the Sears horn...I already have two coming my way soon.
If you check the HCCA classifieds under an offering for Pierce Arrow lights, I think there is a restored horn like your looking for hiding in the lot.
Good luck,
Mike
Scott Rosenthal
Post by Scott Rosenthal » Sat May 29, 2021 10:41 am
Many thanks again gentlemen. I was able to get enough parts together to put this one together.
Regards, Scott
Scott Rosenthal
Post by Scott Rosenthal » Sat May 29, 2021 10:43 am
Regards, Scott
Tbird
Last Name: Bird
Post by Tbird » Sat May 29, 2021 3:13 pm
Eye candy!
