TT Truck rear axle literature
tmodeldriver
Last Name: Hester
* REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
MTFCA Number: 26459
MTFCI Number: 20813
Post by tmodeldriver » Mon Apr 12, 2021 3:45 pm
Does anybody out there in T Model country have a manual for the TT rear axle that you'd be willing to sell to me or make a
copy? I need to tear into mine and replace the gears (7 1/4:1 to 5 1/6:1). Some literature would help so I won't be totally winging it. Please send me a pm if you can help. Thank you. Bob
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
MTFCA Number: 49646
Re: TT Truck rear axle literature
Post by StevenS » Mon Apr 12, 2021 9:48 pm
Robert,
Standard Ford rear end or Ruckstell rear end?
1924 Model T Touring
1924 Model TT Truck
1930 Model A Pheaton
tmodeldriver
Last Name: Hester
MTFCA Number: 26459
MTFCI Number: 20813
Post by tmodeldriver » Tue Apr 13, 2021 12:11 am
It's a standard rear end. Thanks for your reply. Bob
Scott Gilham
Last Name: Gilham
* REQUIRED* Type and Year of Model Ts owned: 23 TT
Post by Scott Gilham » Tue Apr 13, 2021 2:50 am
I'd be interested too in info on these beasts. I've taken several apart now and will need to put together a good one pretty soon.
They appear pretty straightforward but you know what happens when you assume.
StevenS
First Name: Steven
Last Name: Sebaugh
MTFCA Number: 49646
Post by StevenS » Tue Apr 13, 2021 11:01 pm
To me there is two things you will need. One is the Ruckstell Manual from the MTFCA. Here is the link:
https://modeltstore.myshopify.com/produ ... ce-manuals
Even though it is for the Ruckstell rear end, it still has the specs. for the parts for the standard rear end like; axel, bearings, sleeves, axel drive gears, spider gears, spider gear housing, top section of the rear end where the worm gear is, bronze ring gear, and so on. The worm gear assembly for the Ruckstell is the same as the standard rear end and the manual covers that section very well.
The other is Vowel Art on the MTFCA website here is the link for the Model TT stuff (scroll down). It has a good diagram of the rear end for parts, and assembly.
https://mtfca.com/phpBB3/app.php/gallery/album/5
Also, if you have taken a rear end apart, I hope you took many pictures of how it goes together. I did and that really helps. So, that a look at both links and see what you thing. But the standard rear end is really simple to put together. Much simpler than the Model T rear end.
1924 Model TT Truck
tmodeldriver
Last Name: Hester
MTFCA Number: 26459
MTFCI Number: 20813
Post by tmodeldriver » Wed Apr 14, 2021 4:13 pm
Hi, Steven. I've ordered the Ruckstell manual as you suggested. Thanks. Bob
