Ruckstell Fiber Spacers
Topic author - Posts: 3298
- MTFCA Number: 121
- MTFCI Number: 16310
Wanted: NOS Ruckstell fiber thrust spacers. These look like the steel Ford spacers, but are .105" thick, and are slightly a larger diameter.
- Last Name: Gould
Re: Ruckstell Fiber Spacers
Larry, I suspect Ruckstell used fibre washers of varying thicknesses to account for manufacturing tolerances. Or perhaps the washers were not made to exacting standards.. The one I provided you with the Ruckstell years ago was .010 thinner.
- Last Name: Gould
If you're considering making some consider using the red fibre used in the 2 cylinder Ford transmissions.
- Last Name: Morsher
I agree with Richard. I’ve got some red fiber left, Larry. Just yell. IMHO , that is a MAJOR error in the ruckstell rebuilding manual to use a steel washer there , of the wrong size to boot.
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
WHAT??? Elaborate please! Recently rebuilt, Bill
- Last Name: Chaffin
- MTFCA Number: 31705
I've done many that way over the years and all are still going strong. Kinda like replacing the babbit thrust washer and using a bronze instead. How many fiber thrust washers have you found intacked when disassembling an original Ruckstell? To date, I've only found three and they were all well worn. To each his own.
Mark, my feeling is with a well rebuilt axle, it’ll never likely be a problem. There is the rub, though. It takes a big effort to properly set up an axle. Good old fiber washer of the right size for me.
I'm sure the fiber will give good service. Either practice will likely give many years of service. I was taught to use the metal spacer and it has proven to work well.
With wear on the diff housings, wear on the axle gear thrust faces and on the ends of the axles, can a new fibre washer of standard dimensions ever achieve the best result? I replace all the worn fibre washers with a custom made brass/bronze one made from a AU$1.00 coin. There's enough thickness in these to be able to dress them down to the optimal thickness required to make an assembly where axle end float is history.
- MTFCA Number: 14972
- MTFCI Number: 15411
I believe the above discussion is in regards to the large O.D. washer inside the Ruckstell bell housing - not between the axles.
- MTFCA Number: 121
Correct Steve: My belief is Mr. Ruckstell knew what he was doing, and had a reason for doing it! I'm not trying to rewrite the book. I just want the correct parts! I have the fiber washers in two of my cars, and haven't had a problem.
- MTFCA Number: 121
Richard: What is the thickness of the material you have? I believe .105" to be correct. The O.D is slightly larger than the Ford Steel washers. The I.D. is the same.
- Last Name: Gould
Larry I sold most of my red fibre material to the 2 cylinder Ford guys. It came from a stash found in Australia by an early Ford guy some years ago. Tim got some as did others that frequent this forum. If you're interested contact me by phone and I'll investigate further. You probably have my phone number. If not Kim surely does.
Thanks Steve, I went back and re-read the original post and found I was at cross purposes.
Larry, I have a bit of Richard’s stuff still here. I believe that’s .250. I also bought a huge sheet of .125 from Eugene Krystoffy, the alphabet transmission guy. I still have a lot of that, and believe that’s what I used on my rebuild.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
If someone decides to make a run of Ruckstell fiber spacers, I would like to get on the list for a couple, thanks!
- Last Name: Gould
Larry there were two thicknesses of the red fiber I had. The stuff I had saved for myself I gave away for the most part when I unloaded my early Ford stuff. I measured the pieces I still have and they are .060 and .110 inches thick respectively. Thanks for catching the decimal point error, Allan.
- First Name: Bill
- Last Name: Hoffer
Still confused, where does fiber outperform the specified materials in the Chaffin book? Puzzled, Bill
I don't believe one outperforms the other - the steel washer is readily available & the fiber one is not.
Rihard, you might like to move one of your decimal points.
- MTFCA Number: 121
It's not a matter of one out performing the other! The original design used a fiber thrust washer for a reason. It's not up to us to re engineer the part!
Kinda like replacing the babbit thrust washers with bronze eh!
I have enough I can share. Cut your own circles. Let me know size, as I forget. Tmorsher@icloud.com . Tmorsher@icloud.com
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
Mark-touche!
- Last Name: Gould
An interesting note/question. Didnt Ford use bronze thrust washers in early 1916 cars? I had an original 16 with them. Also had an original 1917 car that used babbitt and an original 1919 car that used babbitt. None appeared to have been molested.
Larry, have you a handle on the reason fibre was used in the design. Enquiring minds wold like to know the benefits.
- MTFCA Number: 121
I just measured the only original I have, which is used. It is 3 7/8" O.D. The steel Ford washers are 3 3/4". There is a slight ring around the edge, which shows no wear, and that's where I come up with the .105" measurement. I don't know what they allowed for clearance originally. I have a couple of original Ruckstell installation pamphlets, but don't care to go looking for them! Something in my mind tells me they originally allowed .005".
