SOLD SOLD SOLD SOLD
Topic author - Posts: 138
- First Name: randy
- Last Name: lee
- * REQUIRED* Type and Year of Model Ts owned: 1926 pickup
SOLD SOLD SOLD SOLD
[/attachment]I have 2 buffalo wire wheels good shape (tire on one is 30 x 3 1/2 ) are these worth anything? they look good enough to use...look solid....need blasting to make really nice...
Last edited by halftracknut on Mon May 03, 2021 10:08 pm, edited 3 times in total.
- First Name: David
- Last Name: Mazza
- * REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Re: wire wheels
Literally worth their weight in gold. Like seriously
- First Name: Susanne
- Last Name: Rohner
- MTFCA Number: 464
Re: wire wheels
I don't know about gold... maybe silver...
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
- MTFCA Number: 32419
Re: wire wheels
a picture may produce a golden nugget
- First Name: Pete
- Last Name: Eastwood
- MTFCA Number: 52632
Re: wire wheels
would you like to sell them ?
- First Name: DAN
- Last Name: MCEACHERN
Re: wire wheels
What is that other wire wheel lurking in the background thru the doorway?
Last edited by Dan McEachern on Sat Apr 17, 2021 12:41 am, edited 1 time in total.
Re: wire wheels
You need the hubs on which they mount, and the hubcaps. Then you need to closely inspect the beads on the rims. These an just as easily be rusted away like standard Ford clincher rims. That would mean finding replacement rims and a new set of spokes to rebuild them. The value of your nugget will depend on these factors.
Allan from down under
- First Name: randy
- Last Name: lee
Re: wire wheels
anyone want to guess what they are worth????? I have no idea.....thanks
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Re: wire wheels
Reproductions (made by member) listed for $550 in 2019 viewtopic.php?t=8037
Listing on https://forums.aaca.org/topic/339315-ra ... -and-hubs/
Very rare and nice set of 21 inch buffalo wire wheels. They are in phenomenal shape. They come with a complete set of hubs and lock nuts. Firestone whitewalls are older but still soft and not weather cracked asking $6000
- Attachments
- BUFF.png (807.07 KiB) Viewed 5577 times
- First Name: Kevin
- Last Name: Pharis
Re: wire wheels
There are some wheels that can be run reliably in original condition... if all the spokes are still tight and there is not too much rust in the rims, wheels can be cleaned up and painted, and perform reliably for many years.
The big unknown is how much rust is between the spoke nipples and the rim dimples. This rust can build up and make the spokes feel tight at first... but after driving on the wheels, the rust layer can break down and reveal the true condition of the wheel... loose!
Price... your guess is as good as mine...?
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
Re: wire wheels
Most of the wires I see are too far gone for economical restoration to safe use considering that there are new excellent T quality ones available.
I'm leery of all of them.
- First Name: randy
- Last Name: lee
Re: wire wheels
what you see is many many coats of chipped paint....the wheels are in great shape...spokes are tight and solid.....
- First Name: Eric
- Last Name: Dysart
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1916 Touring, 1927 Runabout
Re: wire wheels
My guess would be maybe $500 a wheel without hubs and caps, if you do a full restoration on each; sandblasting, replacing the rim and any spokes if needed, and a good coat of paint. If you’re not going to do the work, then the price should be less.
Eric
Eric
- First Name: randy
- Last Name: lee
Re: wire wheels
Randy, the photos of the rims show they are good, at that point at least. No sharp edges, no rust in the rim base. If the rest of th rim is like that, you have a good pair. To some one needing them they will have extra value. Now you just need to find that someone.
- First Name: Kevin
- Last Name: Pharis
Re: wire wheels
That rim looks very nice! If it’s that good all around... it would probably clean up nicely
- First Name: randy
- Last Name: lee
Re: wire wheels
they are better than the photo..........these were in dry storage
- First Name: randy
- Last Name: lee
Re: wire wheels
I am planning to attend The Luray Swap Meet and can deliver the wheels to the meet...I need wood wheels , 21" rims, a frame any year, used tires, tubes, drive shaft, front and rear springs, rear end none of which need to be anywhere close perfect....I want to build a T flat wagon to pull grandkids around the farm with my T truck...what do you have to trade???????
- First Name: Jonah
- Last Name: D'Avella
Re: wire wheels
I have a rear end assembly with the driveshaft and everything attached and springs on it, they are rusty, but probably work for a trailer. I also have a front axle with some rusty springs on it. Just curious, why would you want the drive shaft on a trailer?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: wire wheels
radius rod support!
- First Name: randy
- Last Name: lee
Re: wire wheels
jonah, sent you e-mail rl
- First Name: randy
- Last Name: lee
Re: wire wheels
I am going to have these sandblast should I have them primed or bring to swap meet bare metal? these will be for sale or trade for T parts....any questions PM me here or e-mail me...
Re: wire wheels
Definitely prime them. They will rust while you look at them otherwise. I'd use primer/surfacer suitable for lacquer. Then you have a base for both lacquer or enamel. It is still a porous coating, and they should be finish coated as soon as possible.
- First Name: randy
- Last Name: lee
Re: wire wheels
[image]
[/image]-
Re: wire wheels
Randy, if that is your sandblast result, don't worry about priming them. It shows how good the rims are, and that is a benefit when selling.They will need a much more thorough clean-up before painting.
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
Re: wire wheels
Hi From Iowa1 I am interested in the Buffalo Wheels for spares - Depends on what you will consider for fair price? Thanks John
- First Name: randy
- Last Name: lee
Re: SOLD SOLD SOLD SOLD
SOLD SOLD SOLD SOLD
