SUNDAY SWAP MEET
Topic author - Posts: 3327
- Last Name: Chaffin
- MTFCA Number: 31705
SUNDAY SWAP MEET
Good morning everyone. Hope you all are doing well. This week’s Sunday Swap Meet offerings are all good used original items and a couple of new items. Description and prices are as indicated below. In most cases, USPO Flat Rate shipping will be an additional $8.50, unless stated otherwise. Payment by PayPal (preferred) or by check. Message me or call Mark Chaffin (951) 805-0928
Re: SUNDAY SWAP MEET
1. Front license brackets $5.00 SOLD
2. Rear view mirror $5.00
3. Steering gear cover and gears (4:1) $20.00
4. Generator and starter brush assemblies $6.00 SOLD
5. Firewall mounting bracket set (square hole) $10.00
6. Main bearing bolt set $8.00
7. Miscellaneous NH carburetor parts $6.00 SOLD
8. Demountable rim bolt set (32 pieces) $15.00 SOLD
9. Hub bolts and nuts new (20 pieces) $5.00 SOLD
10. Spare tire wire wheel lock nut original $5.00
11. Valve chamber block off plate set $8.00 SOLD
12. Slow speed clutch shaft complete $15.00 SOLD
13. Clutch cam and pedal cam parts $10.00 SOLD
14. Switch wire loom (26-27) $5.00 SOLD
15. Early cast brass hood handle and brass steering column lower bracket $15.00 SOLD
16. Cutout floor pedal steel $10.00
17. Schrader brass valve stem removed from modern tubes (4) $20.00
18. Front frame cross member support bracket set $10.00
19. Brass strap ground cable and extra clamp new $3.00 SOLD
20. Generator cutouts “Ford” reproduction condition unknown $20.00 SOLD
21. Hot air pipe assortment (3) $20.00 plus $15.50 shipping.
22. Early front spindle Dodge Brothers “DB” RHT $50.00 SOLD
23. Front wheel bearings and races (3) Large (1) RHT Outer (1) LHT Outer $45.00 SOLD
24. Schrader Universal air pressure gauge brass $25.00
25. Figure 8 shackles and parts. One piece is later. $25.00
Last edited by Mark Chaffin on Mon May 03, 2021 9:37 am, edited 13 times in total.
#23 sold to Mike.
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Msg. Sent for #12, I'll take it.
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
#1, #14, #19, if available. T. Woods
Hi Terry, #1 only still available. #14 and #19 have been sold.
- First Name: Terry
- Last Name: Woods
Thanks, Mark. I'll pass. Not worth it for the one item that I need the least.
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
I will take #1 if still up.
#1 sold to Bob. Message sent. Thanks Bob!
- MTFCA Number: 14972
- MTFCI Number: 15411
Mark - put my name on # 15, please if still available - I figured you might have been at Tulare.
