COMING TO LURAY with a Deposit Only
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Mon Apr 26, 2021 7:04 pm
Do not feel like hauling everything so here are some items I will be bringing if a deposit is received prior to the event. Please do not request pictures as everything is boxed up..., ask anyone, I do not sell JUNK! Deposit of half is required prior to me hauling.
- 6 Each 30 X 3 1/2 re-spoked Buffalo Wheels with a set of front and rear hubs, plus one extra for the spare tire carrier, plus an aluminum rear
carrier. $6,000.00. Very light surface rust here and there (comes off easy) from about 20 years of storage.
- 4 Each split ring Buffalo Wheels ( 3 each are 20" and 1 each 21" ) with tires, tubes, hubs, caps, and spindles. Set up for vintage Sprint racing.
$4,000.00. Silver powder coated.
- Beautiful used brass Livingston Vee radiator. $2,500.00. Front holes have a slight oval to accept forward movement.
- Chevy 21" disc steel rims (4) with galvanized demountable wheels (5) with three used 4:50 X 21 and two brand new 5:25 X 21 tires (USA Made) with our custom wheel adapters. $2,300.00.
- Both wood hub to either Model T 5 lug spoke wire wheels or Model A 5 spoke wire wheel adapters ( set of 4 )..., set of four, $325.00. Only three sets of each remain.
- Joe Gemsa dual spark head SUPER POWER! All there, needs a quick look over and cleaning $8,000.00. Was custom built for LaRue Thomas.
- One of each, rebuilt small drum stock length rear end, good quality used gears and bearings with upgrades, ie, Fun Products adjustable pinion bearing, modern inner and outer seals, Complete take down! Housings has pitting, but excellent other wise. Have one large drum in the same built, 3:63 to 1 ratios, your choice..., $1,400.00 each.
- One each, 12 rivet (November 18,1912 production started) 1913, converted to large drum, safety hubs, RM Brakes with all hardware, 3:63 to 1, bridge trussed axle to axle. Painted dark blue. Really beautiful nothing held back on the build. Cut down 12 " for a Warford. $2,600.00.
- 2 each 1937-39 Chevy top loader transmissions ready to mount with custom adapter bells, u-joints, etc. (cut down of approx 14" is required of torque tube). $1,400.00 each.
Contact by identifying yourself by means of text four two 3 - eight 3 seven-five 709, email, or this email p.h.leecoburntown at gmail.com
Will add more later,
Hank
More!
- Bailey locking differential (never used) $1,200.00.
- Rebuilt Model T transmissions both small and large drum. Last two, no magnets installed, $1,400.00 each.
- Winfield model B carburetors (2 each) and model BB's (two each)..., Serious inquiries only.
- Brookland Windshields (2 each) $325.00 for the pair.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: COMING TO LURAY with a Deposit Only
Post by Henry K. Lee » Wed Apr 28, 2021 6:51 am
Two wood to Model A wire wheel adapters SOLD! Thanks MTFCA.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Wed Apr 28, 2021 3:27 pm
:lol: My goodness Hank, what don't you have?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Apr 28, 2021 4:22 pm
All Model T to Model A wire wheel adapter kits Sold! Thanks MTFCA!
Thinning the heard as I am going on to other interest Tim! My father has been collecting since the late1940’s.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Apr 28, 2021 7:59 pm
More!
- One short block 1918 rebuilt engine by I believe Russ Potter. Changed out at 200 miles because the customer wanted a true 1917 for his car. $1,800.00. Ready to go.
- One short block 1925 rebuilt engine by us with less than 250 miles, Dunn weighted crank, SS valves, adjustable tappets, 280 cam by Ralph Reeder, Nice performance. $2,200.00. This was in my Speedster when a magnet went though the transmission. Taken down and cleaned. Ready to go.
- One 1926 or 27 short block complete original requiring a refresh of not a lot, EE crank. $500.00.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sat May 01, 2021 10:28 am
Winfield Model BB’s carburetors SOLD! Livingston V radiator SOLD!
Thanks MTFCA!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun May 02, 2021 6:53 am
MORE.....,
Early body kit, appears to be a reproduction of very high quality $1,800.00.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun May 02, 2021 6:56 am
Gemsa Head!!!!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun May 02, 2021 7:00 am
Buffalo Sprint Wheels...,
Buffalo 30 X 3 1/2 (6) Set, hubs, caps, with spare carrier, ....,
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun May 02, 2021 2:50 pm
1926/27 short block SOLD! Thanks MTFCA!
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Mon May 03, 2021 10:34 am
Small drum rear end SOLD! Thanks MTFCA!
I have one other small drum rear end! Completely rebuilt. Here's the small problem, a guy I sold this one to dropped it on the axle nut and bent an axle. I have a serviceable axle for it but no time to change it out! $1,200.00 and you change out.
Hank
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue May 04, 2021 7:06 am
One item added above.
Ron Horton
First Name: Ron
Last Name: Horton
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1923 Roadster, 1915 Speedster
MTFCA Number: 31269
Board Member Since: 2011
Post by Ron Horton » Tue May 04, 2021 9:46 am
I’m sure glad that you live on the other side of the continent from me. It has saved me a good deal of money!!
Ron Horton
Utah
I can’t tell if I’m handling life well these days or I just don’t give a sheet anymore :D :D
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue May 04, 2021 10:03 am
LMAO!!!!!!!
They do have things like airline tickets and U-Haul trucks! Options for spending your children’s inheritance!
