wire wheel adapters
Topic author - Posts: 45
- First Name: William
- Last Name: Rathert
- * REQUIRED* Type and Year of Model Ts owned: 1909, 1915, 1917, 1926
wire wheel adapters
Need to widen wheel base a little for snow tracks. Does anyone make spacers for 1926 wire wheels? Want to go back with originals. Thank you for your help.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Re: wire wheel adapters
Google the lug nut king. I think they have them or will make them for you.
Craig
Craig
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
If your stock then the spacers needed are for a 5 x 5" wheel pattern for 1/2 studs. Note: some are available for 14mm studs which would be too loose. A little? Adapter or spacer
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
I have some of different thicknesses, how much is your little. Made from steel plate.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Have them only in 1/8” and 1/4”.
