Flywheel Balance Jig FS
Topic author - Posts: 4110
- Last Name: Hatch
- MTFCA Number: 49974
Here is a surplus to me flywheel balance jig. Can be also used to balance crankshaft grinder wheels. Heck you can balance anything you can put on it. Can bring to Luray But ONLY if Sold. Email me at address in pictures. Thanks Dan
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
Re: Flywheel Balance Jig FS
email sent
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: BOB
Still available
Be_Zero_Be
Be_Zero_Be
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
- MTFCA Number: 50661
How much and can you ship
- Last Name: Hatch
I will take $700 you pickup at Luray or here.
Here is one like it on eBay check it out
https://www.ebay.com/itm/274616413396
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Can also bring to Hershey
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
This Is a serious tool. I have been Balancing Cranks, Flywheels an Transmission Drums for over 50 Years with One just like Dan's. I have never had a customer question or complain about a vibration on any motor or transmission that I've done since I started to Balance with mine.
- First Name: Bill
- Last Name: Crosby
- Last Name: Tannehill
- MTFCA Number: 49460
Dan & Bill how is the flywheel balance? On the crank or alone by itself. If together how is it counterweighted? If by it’s self how is the fly wheel mounted? Thanks for the info on the neat jig.
- Last Name: Hatch
I first balance the triple gears, then put them on their pins, mount the flywheel on arbor. Flywheel on to stand, find heavy side and remove weight till balanced by same way Ford did drill bit.
Perfect sense, thanks Dan.
- Last Name: Gould
I heard that you cannot use a a static balancer to balance a crankshaft. Fine for flywheels and drums. My experience is to dynamically balance the crank. Then assemble the flywheel and trans shaft as they will run in the car and dynamically balance the flywheel as attached to the crank and trans shaft. I have a very smooth running 10 touring car balanced that way. The triple gears were weight balanced, the drums dynamically balanced. The brake drum and diving plate were balanced as a unit. Again as they were to run in the car. I did the same on a 12 roadster and a 27 roadster. The difference is very noticable.
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- Last Name: Hatch
Back to the top
- First Name: Jacolb
- Last Name: Edwards
- MTFCA Number: 50281
Rgould1910 The Ford crank rods and mains come in at 1.2485 … It is a bent piece of rebar at best even static balanced with brake drum low speed and drive plate is a massive improvement from how Henry built them
Haha can’t forget reverse drum
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
And if you want a real joke, the holes drilled in Model A cranks are just holes. The employees were treated like crap, so they went thru the motion of balancing. Never seen one balanced from the factory.
Just Sayin'
And I am still baffled that this jig has not sold..., Uhmmm.
Just Sayin'
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Dan,
Give me a call later, I will buy it so when I do sell all my Model T tools as a complete working shop it has it!
