Jess Boner rocky mountain style brakes
Topic author - Posts: 163
- First Name: William
- Last Name: Weiss
- MTFCA Number: 20215
- MTFCI Number: 16460
2 new sets of Jess Bonar Rocky Mountain brakes
One 1926 1927 and one up to 1925
300.00 each Luray delivery possible.
Thanks Bill
Thanks Bill
- Last Name: Davis-Williams
- MTFCA Number: 49778
Re: Jess Boner rocky mountain style brakes
Hello! I'm interested in the 26-27. Sending you an email now.
George
George
George Davis-Williams
Lake City, MI
1926 Tudor
Lake City, MI
1926 Tudor
- First Name: Brian
- Last Name: Healey
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1915 Canadian touring 1915 roadster boat tail speedster
Bill. I'll take the 25 and older set. Pick up in luray. I'll send you PM
- Last Name: Franko
- * REQUIRED* Type and Year of Model Ts owned: 1914 & 1927
- MTFCA Number: 25233
- MTFCI Number: 25597
Does the rod connect to brake pedal or emergency handle? I have the same brakes but never installed them on my 14 . Never heard of this system. Thank you in advance reply. Tim
- First Name: G.R.
- Last Name: Cheshire
- MTFCA Number: 29759
Franko they connect to the brake pedal the brake pedal for those brakes has an ext. off the bottom to connect them.
- Last Name: Franko
That’s what I thought, but the rod isn’t long enough to reach. I’ll have to check again. Some part may be missing.
- MTFCA Number: 52564
Looking at the photo, the short rod has the boot that wraps around the brake pedal shank, which would have been connected above the shaft not under. The pre 1926 AC small drum cable brakes hooked up the same way.
1920 Dodge touring
1920 Dodge touring
- First Name: Neil
- Last Name: Haywood
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster
I’ll take the small drum set. Where are you in Southern Vermont? I’m in Stockbridge, Ma so could arrange to pick up.
- First Name: Jonah
- Last Name: D'Avella
I will take the 27 brakes, sending email now.
- Last Name: Hatch
- MTFCA Number: 49974
Whoever buys the small set should stop by my trailer at Luray. I have a part set that will be cheap. Dan
