Jess Boner rocky mountain style brakes
BlackTinLizzie
First Name: William
Last Name: Weiss
MTFCA Number: 20215
MTFCI Number: 16460
Post by BlackTinLizzie » Sun May 09, 2021 7:22 am
2 new sets of Jess Bonar Rocky Mountain brakes
One 1926 1927 and one up to 1925
300.00 each Luray delivery possible.
Thanks Bill
gldavis
Last Name: Davis-Williams
MTFCA Number: 49778
Re: Jess Boner rocky mountain style brakes
Post by gldavis » Sun May 09, 2021 8:10 am
Hello! I'm interested in the 26-27. Sending you an email now.
George
George Davis-Williams
Lake City, MI
1926 Tudor
brian2264
First Name: Brian
Last Name: Healey
* REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1915 Canadian touring 1915 roadster boat tail speedster
Post by brian2264 » Sun May 09, 2021 9:11 am
Bill. I'll take the 25 and older set. Pick up in luray. I'll send you PM
Franko
Last Name: Franko
* REQUIRED* Type and Year of Model Ts owned: 1914 & 1927
MTFCA Number: 25233
MTFCI Number: 25597
Post by Franko » Sun May 09, 2021 9:18 am
Does the rod connect to brake pedal or emergency handle? I have the same brakes but never installed them on my 14 . Never heard of this system. Thank you in advance reply. Tim
ironhorse
First Name: G.R.
Last Name: Cheshire
MTFCA Number: 29759
Post by ironhorse » Sun May 09, 2021 9:59 am
Franko they connect to the brake pedal the brake pedal for those brakes has an ext. off the bottom to connect them.
Franko
Last Name: Franko
MTFCA Number: 25233
MTFCI Number: 25597
Post by Franko » Sun May 09, 2021 10:26 am
That’s what I thought, but the rod isn’t long enough to reach. I’ll have to check again. Some part may be missing.
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Post by Mark Gregush » Sun May 09, 2021 10:55 am
Looking at the photo, the short rod has the boot that wraps around the brake pedal shank, which would have been connected above the shaft not under. The pre 1926 AC small drum cable brakes hooked up the same way.
1920 Dodge touring
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Sun May 09, 2021 3:59 pm
I’ll take the small drum set. Where are you in Southern Vermont? I’m in Stockbridge, Ma so could arrange to pick up.
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Post by Jonah D'Avella » Mon May 10, 2021 7:17 am
I will take the 27 brakes, sending email now.
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue May 11, 2021 8:35 am
Whoever buys the small set should stop by my trailer at Luray. I have a part set that will be cheap. Dan
