Early 7 Rivet Engine Pan
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Thu May 13, 2021 9:24 am
Original 1912 or earlier 7 rivet engine pan, with the reinforcing plate under the seven arm rivets. Has been welded and repaired in the inner corners, decent work, will need to be dressed. Evidence of extra brazing evident around the arms, nose and various places, obviously very old reinforcing by previous owner. It has a brazed patch on the bottom of the hump, also done a very long time ago. It is still a very solid pan, no cancer or rust out evident. Just needs to have some of the welds and brazing cleaned up for appearance. Very hard to find pan. Can provide more detailed pictures if needed. Pick up required or arrange your own shipping. 500.00
Michael A
First Name: Michael
Last Name: Abbott
* REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
MTFCA Number: 49918
Re: Early 7 Rivet Engine Pan
Post by Michael A » Thu May 13, 2021 8:36 pm
Email sent
Michael A
Michael A
First Name: Michael
Last Name: Abbott
MTFCA Number: 49918
Post by Michael A » Thu May 13, 2021 9:23 pm
I’ll take it Ed once pictures confirm it’s all correct.
Thank you Michael A
Michael A
First Name: Michael
Last Name: Abbott
MTFCA Number: 49918
Post by Michael A » Sat May 15, 2021 9:12 am
Thanks Ed, your correct shipping is very high out of Idaho
Thank you for check this out for me much appreciated.
Good luck, the pan is very solid.
Regards Michael
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Sat May 15, 2021 12:39 pm
There was a nice one that sold at luray for 500.
Michael A
First Name: Michael
Last Name: Abbott
MTFCA Number: 49918
Post by Michael A » Sun May 16, 2021 10:50 am
Thanks Joe
