Looking for a pair of grooved rear axle outer bearings.
I will be happy to pay a little more if you have some that are in really good shape.
Thank you...Bryan
WTB - Grooved rear axle outer bearings
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
- MTFCA Number: 27737
Re: WTB - Grooved rear axle outer bearings
Hello Bryan, I sent you an email.
- First Name: David
- Last Name: Dewey
- MTFCI Number: 19936
it sure would be nice if Hyatt could tool up to make a run of these. Would think there is enough demand? Are T rear axles the only use for them?
T'ake care,
David Dewey
David Dewey
- First Name: Art
- Last Name: Mirtes
- MTFCA Number: 32489
- MTFCI Number: 24068
Hyatt made their last wound roller bearing in 1989.
Art Mirtes
Art Mirtes
- First Name: David
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout
- MTFCA Number: 50076
Looking for some also.
David - Yukon, OK
- Last Name: Hatch
- MTFCA Number: 49974
You could contact Hyatt and is what they say.
I was going to make another run of special thread taps for the pinion bearings bolts. Needed 25 to make a run, only had 12 reply’s, so no taps. Dan
- First Name: Art
- Last Name: Mirtes
The Hyatt factory is shut down and has been empty for over a year. The winding machine was scrapped over 30 years ago. There are other cylindrical roller bearings that can be used in their place successfully if properly installed. Properly installed is the key.
Art Mirtes
Art Mirtes
