Ford service tools
KimDobbins
First Name: Kim
Last Name: Dobbins
* REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
MTFCA Number: 8243
Ford service tools
Post by KimDobbins » Fri May 14, 2021 11:03 am
5z197 rear spring perch 40.00
5Z210 flywheel cap screw 20.00
3z501 piston pin bolt 10.00
5z817 carb bolt wrench 20.00
5z152 rear axle housing 10.00
5z195 Ford tappet wrench 5.00
5z1834 ? 5.00
Band adjustment wrench 10.00
Waldon flywheel cap screw 15.00
Waldon #4 rod wrench 10.00
Kdmks AT att.net all plus shipping.
* REQUIRED* Type and Year of Model Ts owned: '13, '15, '19, '23
Re: Ford service tools
Post by Scott_Conger » Fri May 14, 2021 6:42 pm
Would like to buy the rear spring perch wrench, please
email sent
NH Full Flow Float Valves
KimDobbins
First Name: Kim
Last Name: Dobbins
MTFCA Number: 8243
Post by KimDobbins » Sat May 15, 2021 11:20 am
Scott, sorry it was already sold. These are the tool I have left.
Post by Scott_Conger » Sat May 15, 2021 1:29 pm
after you're done selling wrenches, do you mind if I use your photo for a "want ad" for a perch nut wrench, in a few days?
thank you.
KimDobbins
First Name: Kim
Last Name: Dobbins
MTFCA Number: 8243
Post by KimDobbins » Sat May 15, 2021 7:31 pm
No problem, that's the only one I've ever had.
