Bosch magneto switch F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon May 17, 2021 2:08 pm
Nice complete and tested for proper operation, American Bosch magneto switch works on DU-4 and other magnetos as well. $165 domestic postage included.
Layden Butler
First Name: Layden
Last Name: Butler
Re: Bosch magneto switch F/S
Post by Layden Butler » Tue Jul 20, 2021 4:26 pm
Back to the top!
TRZim
Last Name: Zimmer
* REQUIRED* Type and Year of Model Ts owned: 1911 touring 1914 touring 1915 speedster
MTFCA Number: 15920
Post by TRZim » Fri Aug 06, 2021 9:34 pm
I'm interested in switch. Doesn't it need 2 terminals, one to mag and one to ground. How does this one work? On should go to mag and off to ground.
Tom Zimmer
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Aug 07, 2021 12:16 pm
The terminal on the switch connects to the magneto. That terminal is grounded to the shell of the switch when in the OFF position to ground and kill a high tension magneto. If the shell is bolted to a grounded metal panel then a ground wire is not needed. It the switch is mounted to a wooden panel or otherwise ungrounded then a ground wire from the shell to the car frame or other ground will be needed.
