FS model T tools, Z tools, Stevens, KRW
Topic author - Posts: 1245
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
Stevens cam nut wrench, $125, KRW thrust cutter, $300. Ford Z main bearing wrenches, $30 each, Z cam nut wrench, $45, Z u joint wrench, $35 each, Z exhaust nut wrench, $20, Z generator gear puller, $35, Ford hub puller, $60, Waldon #4 rod wrench, $10, Z pinion gear wrench, $35. All plus shipping. Kdmks AT att.net.
- First Name: Kim
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
Re: FS model T tools, Z tools, Stevens, KRW
Is that one T handle a 5-Z-162 0r a 5-Z-165 ? If it is a 162 I will take it. Thanks
- First Name: Keith
- Last Name: Morford
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touriing, '27 Roadster, 1923 TT
I would be tickled to have the Stevens cam nut deal.
- First Name: Kim
Stevens cam nut wrench and generator gear puller are sold.
- First Name: Colin
- Last Name: Mavins
I sent you a pm about the exhaust nut wrench and the square main bolt wrench Thanks Colin
- First Name: Kim
Square head main bearing wrench and exhaust nut wrench are sold.
