Right hand Hogs Head for starter car with lower steering bracket.
400.00 plus shipping
Right hand drive Hogs Head with lower steering bracket
Topic author - Posts: 163
- First Name: William
- Last Name: Weiss
- MTFCA Number: 20215
- MTFCI Number: 16460
- First Name: Jeff
- Last Name: Lee
Re: Right hand drive Hogs Head with lower steering bracket
Hi
Email sent to inquire about your hogshead.
I have a friend here in Nova Scotia that would like to convert his early RHD T to a starter. He is finding hand cranking getting a bit difficult these days.
Jeff Lee
Nova Scotia
Canada
Jeff Lee
Nova Scotia
Canada
I believe the lower bracket is one from a TT. The car type does not have the boss around the side bolt hole. The block shown with it may have been used to adapt it to the narrower car frame. I do not know if the hole in the side of the frame has to be re-positioned to accept this bracket.
Hope this helps.
Allan from down under
Hope this helps.
- First Name: Brent
- Last Name: Reeb
- * REQUIRED* Type and Year of Model Ts owned: 1914
Hello,
I would like to buy your hogs-head
Please email where to send check
to bwreeb@comcast.net
Thank you
Brent
Thank you
Brent
- Last Name: Weiss
Sold pending funds
Thanks MTFCA
Thanks MTFCA
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
There is a circle behind the Magneto Post with two numbers and a letter in it that tells you what year the RHD cover was made.
