Neat pair of electric sidelights. About 4 1/4” overall diameter. These came to me with sealed beams installed. I replaced those with some clear convex glass lenses , took most of the dents out of the brass bodies, and had them powder coated. Finish up to suit yourself, and I’d be glad to include the sealed beams , no extra charge. These are as original, clear to the front, red to the rear.
These would great for extra lights on a T. I used a similar pair on a highwheeler that I’ve since sold. I mounted them down low on the chassis. Extra lights are never bad on a horseless carriage, especially period correct ones. Those worked as small headlights/tailights. Perhaps you can think of a good use. I have $125 in them before I did anything, so without the mounting brackets, how about $135 ppd? If you want the mounting brackets, an extra $40 would be appreciated. If not, I’ll consider that my profit when I sell those separately.
This is a unique set, left and right construction. Very nicely made overall. Tmorsher@icloud.com to reach me.
