1915 Engine transmission Frame Ruckstell FS Santa Cruz
Topic author - Posts: 83
- First Name: Daniel
- Last Name: Kraft
I have a 1915 block with a narrow pan and transmission, also included is several buckets of the original hardware. The cylinders will need to be bored and the deck surfaced, one bold is broken off in the head and will need to be removed. Overall it’s a nice looking block, no cracks that I can see or repairs.
There’s also a ruckstell axel, I disassembled it and ran the parts through a parts cleaner. In my opinion all the gears look really good, except I’d replace the ring gear.
The radiator, early frame, front end, and buckets of spare parts are also included.
$2000 local pick up only.
Call Daniel 831-278-2742
- Attachments
- 47CE32AA-E03C-446C-842B-CB11E00118DA.jpeg (142.41 KiB) Viewed 3328 times
- 86D99382-53FC-4787-9CEA-DBCB137B7894.jpeg (123.93 KiB) Viewed 3328 times
- CD866653-D90F-4B0C-8B9A-C5E7C9B80CE6.jpeg (148.35 KiB) Viewed 3328 times
- Last Name: Kraft
Re: 1915 Engine transmission Frame Ruckstell FS Santa Cruz
More pictures.
- Attachments
- C0E53769-680D-40B2-837F-1D2D4B6AF20F.jpeg (131.79 KiB) Viewed 3327 times
- 84DDF558-1D58-4EC0-A2C5-8ECE524D085D.jpeg (143.74 KiB) Viewed 3327 times
- 362CFF27-B0E4-44EC-8083-1AD090B7B33A.jpeg (156.99 KiB) Viewed 3327 times
- Last Name: Kraft
More picture
- Attachments
- 135415C0-D74E-42DF-888F-E72F6853D9DC.jpeg (145.3 KiB) Viewed 3327 times
- 86ED53D3-0CA1-49C8-AF96-2D3156D7BF94.jpeg (136.12 KiB) Viewed 3327 times
- C5E89186-4345-47AF-BC52-E5F5C2CB5DAB.jpeg (119.03 KiB) Viewed 3327 times
- Last Name: Kraft
Ruckstell internals, thrust washers are there, just hiding.
- Attachments
- 8DBFECF3-C86B-4CF3-9FC8-92111A0620F1.jpeg (160.43 KiB) Viewed 3322 times
- Last Name: Kraft
More Ruckstell pictures
- Last Name: Kraft
$1700 local pick up
- Last Name: Saylor
- MTFCA Number: 1695
- MTFCI Number: 23870
Pack it up and bring it all to the Mother Lode Model T Swap Meet, June 6, in Auburn, Ca.
- Last Name: Kraft
I wish I had time next weekend, then I would do that.
$1500
$1500
- Last Name: Kraft
$1200 for the lot pick up only
- Last Name: Kraft
I’ve decided to part it out, $800 for the Ruckstell. It’s also listed on eBay.
How much for the engine block?
- Last Name: Kraft
The Ruckstell sold. I’ll sell the rest in one lot or parted out if you come and get it. Wayne would you want just the block or the pan and transmission?
- Last Name: Kraft
$350 for the block
$200 for the pan
$200 for the transmission
$100 for the frame and front axel.
$200 for the pan
- Last Name: Kraft
$300 for block
$175 for transmission
$175 for pan
$100 for frame and front end.
Will not ship these
$175 for pan
Will not ship these
Thanks Daniel K. But that is more than I dare put out right now for a block I really don't need.
- Last Name: Kraft
