FS: Early Nonpareil Double Twist Horn
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Sun May 30, 2021 2:51 pm
FS: One Double-Twist horn by Nonpareil. Mounts on the Driver side Bell-up so appropriate for an Early Model T, possibly as early as 1909. This is an early-style horn that is supposed to have a scalloped horn grille, but sadly this grille is missing. The bell is beat up but probably restorable by someone willing to put the time into it. The usual dents and dings are present but the brass is solid. The fitting for the reed is damaged and will likely need replacement. Obviously if you want to remove the bell and install a 1910-1912 style bell and grille, that's your choice. Asking $225 not including shipping. Thanks for looking.
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Re: FS: Early Nonpareil Double Twist Horn
Post by Rodger Erickson » Sun May 30, 2021 2:52 pm
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Sun May 30, 2021 2:53 pm
Scott Rosenthal
Last Name: Rosenthal
* REQUIRED* Type and Year of Model Ts owned: 12 Towncar, 12 Touring, 09 Touring
Post by Scott Rosenthal » Mon May 31, 2021 4:14 pm
Hi Roger:
Sent you a PM.
Scott 513 378-4235
Scott Rosenthal
Post by Scott Rosenthal » Tue Jun 15, 2021 8:33 am
Hi Roger:
I sent you the PM noted here and left a message with Wayne at your shop, related to this horn.
Scott Rosenthal
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Sat Jul 16, 2022 7:22 pm
I'll take $165 for this, not including shipping.
