1910 two piece grive shaft
Topic author - Posts: 969
- Last Name: Gould
This was the first two piece drive shaft used after the discontinuance of the one piece drive shaft without the spool and roller bearing. Noice the rear casting is the same as was used on the earlier one piece variety, clearly different than later two piece models. Comes with the correct early ball and retaining ring with the raised boss. Exceptional condition. $900. plus shipping. BTW, I also have separately listed the T 191 spool that goes with this driveshaft, also in exceptional condition $200. Finally I have 1910 rear axle housings with 3/8 inch studs for sale at $2750. All are correct for an early to mid year 1910 model car.
- Last Name: Gould
Re: 1910 two piece grive shaft
Drive shaft is sold
