Late 12 early 13 3 rivet pan with tapered arms and 1912 style front casting, $300
Sets of radius rods, straight, good forks, some thread repair needed, $125 a set
1910 6 rivet rear end housings 3/8" studs, $2500 SOLD
DB front axle, needs thread repair bottom forks, otherwise good, $300
1909-10 steering column, restored original with correct no hole bracket, $1700 SOLD
1912 steering column with correct bracket, $600
Early brake rods, repo with original clevises, $75
1913 drag link, no ends, $75
Late 10, early 1911 6 rivet rear end housings, $2500
CORRECTION. Original 1909-10 timing gear cover for open valve engine, $600 SOLD
Early cast cam handbrake with diamond shaped release, $175 SOLD
1909-10 repo bare hogshead, narrow gage, $1000. SOLD
1909-13 parts final prices
Topic author - Posts: 989
- Last Name: Gould
