Wanted Bittner Coils
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Wed Jun 16, 2021 10:49 pm
Looking for Bittner coils. New or used.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Re: Wanted Bittner Coils
Post by TWrenn » Thu Jun 17, 2021 10:09 am
Good luck. Bittner is like all but vanished. But, if I'm not mistaken, I thought I heard those coils were from a Ford Taurus.
Maybe Jim Golden will chime in, he's pretty knowledgeable in TruFire
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Thu Jun 17, 2021 10:17 am
In addition to his Truefire units, I believe that Ed Bittner also used to offer rebuilt stock Ford coils.
If you really mean that you want a replacement coil pack for a Truefire unit, I have one, PM me if interested. You will have to transfer the high tension leads from your old coil pack to the new one.
Post by TRDxB2 » Thu Jun 17, 2021 10:43 am
I tried to find some information about Bittner Coils and how to identify them. Having said that, there are two possibilities. One maybe the "coils" used inside the Tru-Fire box and the other are the standard coil boxes that Bittner used to rebuild coils.
Model T Ford Forum: Forum 2012: What is black substance inside Bittner coils? http://www.mtfca.com/discus/messages/25 ... 1343845859
By Erich Bruckner, Vancouver, WA on Monday, July 30, 2012 - 06:52 pm:
And don't tell me its MBRT either. And any idea how to liquify it/remove it?
By Tom Miller, Mostly in Dearborn on Monday, July 30, 2012 - 07:09 pm:
His website says specially formulated polyurethane. If that's the case, it's not going anywhere without damaging the windings
By Erich Bruckner, Vancouver, WA on Monday, July 30, 2012 - 08:17 pm:
So unrepairable by standard means is what I'm hearing?
Coil inside the Tru-Fire System http://www.mtfca.com/discus/messages/33 ... 1385090181
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu Jun 17, 2021 11:35 pm
Sorry. Not for sale.
I bought a set of Bittner coils to run in 1919. I was super impressed, so I bought a metal top set for my 1915.
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Sat Jun 19, 2021 9:40 am
I am looking for the individual coils.
MTFCA Number: 52564
Post by Mark Gregush » Sat Jun 19, 2021 12:38 pm
Ok so I have to ask; are you talking about original style coils and if so, how would one know they are Bittner coils? Are they marked in some way? Someone, not me, may have them sitting on a shelf and may not know.
1920 Dodge touring
Post by TRDxB2 » Sat Jun 19, 2021 1:23 pm
I have the same question. The discussion I noted above indicates that a specially formulated polyurethane mixture was used to fill the case. So one way to tell may be to open the wood and see what's inside. A Pandora's box, will it be worth the effort? KWT says he has some maybe he can say if there are any external markings to identify them
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sat Jun 19, 2021 1:29 pm
I have a set of brass tops also - I'll see if there are any indentifiers.
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Sat Jun 19, 2021 1:53 pm
Here’s a couple pictures. If you look at the windings coming out of the top you can see they are flat bars and have a plastic sleeve. Here’s a picture of the “goods”.
Post by TRDxB2 » Sat Jun 19, 2021 2:39 pm
Well pictures are worth a thousand words. The top is a dead give-a-way. Parts look easy to replace but the coil winding is not what the suppliers have. Any way to ID it - or might be be hand made and that is what might make it a standout coil.
MTFCA Number: 52564
Post by Mark Gregush » Sun Jun 20, 2021 9:45 am
So from the outside it would only be the plastic sleeve that would be different and maybe cleaner. The late KW coils used the flat bars also. Thank you for the pictures. Now I (others too) know. I like the bridge between each pair of mounting bolts.
1920 Dodge touring
Post by TRDxB2 » Sun Jun 20, 2021 12:10 pm
One thing that may be different is that there appears to be three secondary coils inside that plastic sleeve while the standard is 2 secondary coils.
I came across something too that I had not been aware of about running on magneto that is worthy of noting. This link also covers some interesting technical facts about running on 6v vs 12v. http://www.mtfca.com/discus/messages/25 ... 1337703482
By Mike Kossor on Tuesday, May 15, 2012 - 10:50 pm:
"...I'd also like to acknowledge the merits of the stock ignition system. ... Designing the magneto output voltage to increases proportionally with engine speed which functions to automatically reduce the coil dwell time needed achieve the necessary spark energy; in effect providing automatic timing advance to improve performance was amazing. The original Model T ignition system is a true electro-mechanical marvel well worthy of preservation..."
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Tue Jun 22, 2021 7:48 pm
Note that the Bittner Coil is much lighter, due to no tar inside, so weighing one that looks newer should be a give away.
MTFCA Number: 52564
Post by Mark Gregush » Tue Jun 22, 2021 10:08 pm
ya I was thinking after I posted about being lighter, but also thought about all the guys that used silicon to hold the capacitor in after taking the glass devider, old capacitor and any wood blocks out, just leaving he coils.
1920 Dodge touring
MTFCA Number: 52564
Post by Mark Gregush » Sun Jun 27, 2021 6:22 pm
I looked at some new looking coils Friday. They were the light weight coils but did not have the ring around the center core. I am 99% sure they were not the coils in question. SO you can not go on weight alone. The flat stock used in the center core was wider and just not the same finish as what is shown above.
1920 Dodge touring
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Sun Jun 27, 2021 6:42 pm
Thanks for checking.
Still looking. No luck so far.
