FS: Steven's Front Axle tool frame
Topic author - Posts: 387
- First Name: Jack
- Last Name: Putnam
- MTFCA Number: 13833
- MTFCI Number: 13353
For Sale: Steven"s Front Axle repair tool Frame. Reproduced in cast iron, as the original. It is used to repair the worn king pin holes in the front axle of the Model T. This is the frame only as you will need the reamers and inserts available elsewhere.
$275 plus $12 shipping in the USA. I will accept a check or PayPal at jputnam@wcoil.com . Limited production, USA made.
- First Name: Paul
- Last Name: Bourgeois
- Board Member Since: 2006
Re: FS: Steven's Front Axle tool frame
Jack, I was wondering if you still have any Steven’s tools left. Can’t seem to find anyone up here in Vancouver,BC Canada.
Thanks, PaulB
Thanks, PaulB
- First Name: Jack
- Last Name: Putnam
Yes, I still have the Steven's Frame available. Contact me at jputnam(at)wcoil.com. PM's on this forum don't always get through.
- Last Name: Tannehill
- MTFCA Number: 49460
Caution: this tool will make you extremely popular with anyone that has a model T or is building 1 from scratch. I bought one from Jack a few years ago and the other parts from Dan at the same time. Then I stopped answering my phone & door. Ha, great tool and insert plus taps
- Last Name: Hatch
- MTFCA Number: 49974
John is correct. This is one of the best tools made for a Model T.
- First Name: Jack
- Last Name: Putnam
I have the Steven's frame in stock and available now.
- First Name: Jack
- Last Name: Putnam
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
As a newbie who is learning about my "T" can you tell me what this actually does? Doesn't the "T" have a kingpin that fits snugly in the axle and into bushings of the spindles?
Chris H, Yes, the king-pin should be tight in the axle, and the spindles have bushings in them. Over the many years, many king-pins became loose, and wore the axle. Because of the way the weight of the car forced the king-pin to one side, they tended to wear the holes off center. It is nearly impossible to get a repair properly centered without one of these tools. And if a repair is not properly centered, you will forever have issues with the caster and camber. Original era tools like this are somewhat rare, so we are grateful for people like Jack P that have taken the effort to reproduce a faithful, and accurate, copy.
Another thing that can happen, because the king-pin is threaded into the lower end, and tends to wear most on the top end? Simply replacing the king-pins with new ones can sometimes stress the threaded end, and they can sometimes break! A long-time very good friend of mine has a Rajo powered racing car. Many years ago, he was very fortunate that while doing 90 mph (YES! Clocked at 90!) when the left front king-pin broke, he was able to skillfully guide the car onto the shoulder of the road with the left front wheel cocked back about 45 degrees. Fortunate, in that the broken king-pin hanging down from the top held the wheel sort of in place long enough that he could regain control and pull over.
He is not the only person I have known to have a king-pin break that way. Just the only one I know that did so at 90 mph.
I don't have one of these tools. Fortunately, I have never needed one. I have always been able to find an axle with both ends all good. But it is something I check on every T I put together.
- Last Name: Hatch
Picture worth 1000 words. https://youtu.be/7DNGT7P79vg
Dan
Dan
- First Name: Jack
- Last Name: Putnam
- First Name: Jack
- Last Name: Putnam
Steven's front axle frame tool is in stock and available. If you have questions I can be reached at 419-306-3966. Thank you Jack
