$10 and below ADDED ITEMS/REDUCED PRICES ALL SOLD
Tbird
Last Name: Bird
Post by Tbird » Sat Jul 17, 2021 9:39 pm
I have several parts here that are between $10 and .25. Most of these items are NEW and will be stated, otherwise they are used.
All prices plus shipping. Some I have several sets and will be noted.
mikebird@lifeattheridge.net or 574-584-6744
If you need a picture or two let me know
#1 ZIM All Steel Valve Grinder NEW- $5 SOLD
#2 Drive Shaft Ball Thrust Collar 11-27 4 sets- $2 per set
#3 Drive shaft Thrust Ball and retainer assembly 2 sets NEW- $5 per set
#4 Rear Axle Roller Bearing Pair NEW- $5 for the pairSOLD
#5 13-22 Key, brass, flat style, only for switches on coil box NEW- $1 SOLD
#6 Neoprene Rear Axle Seal pair NEW 3 Sets- $5 for the pair ALL SETS SOLD
#7 Tire Hose Repair Kit for Model A NEW- $1 SOLD
#8 5/16 x 3/4 Rivets 5 pack NEW- $.50 SOLD
#9 26-27 Carb Heat Plate support NEW- $.50
#10 Drive shaft bushing NEW- $2
#11 Ignition Key Switch Accessory 4 position for starter solenoid NEW- $3
#12 26-27 Rear Axle Leather Oil Seals- $3
#13 09-13 Glazed Coil Box Tubes 1 complete set of 10- $10 SOLD
#14 Pitman Arm very little wear on ball- $3
#15 Drive Shaft Nuts (2 sets) NEW- $1 1 NUT SOLD
#16 Reverse Pedal Rubber Pad USED still in very good shape- $1
#17 Stewart Speedo Gear 16 tooth 8 pitch Black Delrin NEW- $10 SOLD
#18 AC Speedometer Road Gear 1920 and up. Wood or wire wheel mount- $5
#19 Transmission clutch springs (2) in very good shape -$5 each
#20 Brake and Reverse Pedals and shafts Later style smooth pedal heads-$5 for both
#21 Crank Ratchet USED- $1
#22 Brake and Clutch Pedal Rubber Pads for 26-27 were NEW but show signs of cracking on side of C pad but no wear on tops- $1
#23 Original High Head Bolts for 18-27 (14 bolts total) -$10
#24 Crank Handle Pin for 15-22 NEW- $5
#25 2 Thrust Washer Brass Minimal wear- $5 for the pair SOLD
#26 Thrust Plates Steel (8)- $1 per plate 4 Plates SOLD
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Re: $10 and below
Post by Ruxstel24 » Sat Jul 17, 2021 10:00 pm
I’m in for the RN12YCs if still available. They fit my H-D. :)
Sent you an email Mike.
Dave
catbol
First Name: Ronald
Last Name: Bolser
* REQUIRED* Type and Year of Model Ts owned: 1925 Cab Top Light Express PU, 1925 Touring,1922 Coupe
MTFCA Number: 29506
MTFCI Number: 23862
Re: $10 and below
Post by catbol » Sat Jul 17, 2021 10:14 pm
Mike,
Sent you an email. I'll take #2 Champion 525 plugs.
Ronald Bolser
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Re: $10 and below
Post by DontKnowMuch » Sat Jul 17, 2021 11:14 pm
Mike
I sent you an email with a couple of questions and a list of parts I would like to buy.
Dennis
Tbird
Last Name: Bird
Re: $10 and below ADDED ITEMS/REDUCED PRICES
Post by Tbird » Wed Aug 04, 2021 10:09 am
Added Items and Reduced Prices.
Tbird
Last Name: Bird
Post by Tbird » Thu Aug 05, 2021 8:24 am
All Remaining Items now SOLD
