2 pc driveshaft end $50
Topic author - Posts: 3384
- Last Name: Morsher
Here’s a two piece driveshaft ball. Looks like someone’s done some work on this, may need some more. If you’re looking for a fixer-upper, here you go. Never rusty, so at least I leave you on a positive note ! $50 + post. Tmorsher@icloud.com to reach me. Thanks!
- Last Name: Tannehill
- MTFCA Number: 49460
Re: 2 pc driveshaft end $50
Tim looks like someone may have used an old style 4th main roller bearing. If I remember correctly you had to cut some off the bell for it to fit in the hogshead recess.
$50 delivered to your mailbox, Tmorsher@icloud.com
