WTB Tailight and spindle bolt
Topic author - Posts: 408
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
- MTFCA Number: 50718
WTB I need a tailight for a 22 touring. It mounts on the rear spare carrier. Also need one tie rod bolt with oil filler. Thanks, Art
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Re: WTB Tailight and spindle bolt
I have the tie rod bolt. I have many taillights need to see if one matches your description. Is it the type with a single bolt out the back? ALSO single or double contact?
- First Name: Art
It has the single bolt out the back. Art
Here is what I have. The tie rod bolt is unused and appears to be very new (may be hardened). I also have some good used ones. This is one of the tail lights I have (the others need much restoring). This is for a single contact bulb and is solid (also have the clear celluloid for it). I can configure a double contact. I'll send you an email
- First Name: Art
That is the correct tailight. I also need one tie rod bolt with oil cap. Art
