NORS 1924-25 Rdst-Coupe Fender.
BobP
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 1914 tr, 1916 rdts, 1921 tr, 1923 rdst, 1925 cp. 1927 pu, 1927 tr.
MTFCA Number: 26652
Post by BobP » Fri Jul 30, 2021 2:04 pm
For sale unused NORS 1924-25 left rear fender for a coupe- roadster. This is a hi-quality older heavy repo. New ones are $465. I will take $150. No texting. Call 507 458 6778. S. Mn.
MTFCA Number: 52564
Re: NORS 1924-25 Rdst-Coupe Fender.
Post by Mark Gregush » Sat Jul 31, 2021 11:48 am
Would be coupe only. The roadster used the same fender as the touring.
1920 Dodge touring
BobP
Last Name: Peterson
MTFCA Number: 26652
Post by BobP » Sat Jul 31, 2021 2:03 pm
They are stamped coupe and roadster but I think you are right. So let us say 1924-25 Coupe.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sat Jul 31, 2021 6:18 pm
There is documentation here in the Encyclopedia & other documentation supporting the fact that the Runabout did utilize the full skirt rear fender same as the Coupe in 1925 - I had a late production '25 Runabout with the full skirt rear fenders.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sun Aug 01, 2021 11:33 am
Don Skille has an early '25 roadster with the coupe fenders. They appear to have always have been on the car.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Aug 01, 2021 12:51 pm
Larry- question- So if someone had them on a coupe, would you say that the coupe had roadster fenders on it?
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
MTFCA Number: 23703
MTFCI Number: 23153
Board Member Since: 2009
Post by FordFool » Sun Aug 01, 2021 1:31 pm
Good question Dan 🤪 Larry will probably come up with a good answer.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Aug 01, 2021 1:41 pm
Funny Dan !!!
Missed you & Mary on the Spokane Tour !
namdc3
First Name: Nikolaus
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Mon Aug 02, 2021 2:25 pm
Here's two not great data points, but food for thought. This Ford advertisement artist's rendition and these photographed runabouts appear to have the 8850B/8851B rear fenders.
Post by Scott_Conger » Mon Aug 02, 2021 3:12 pm
Nikolaus
your eyes are better than mine. I can come to no such conclusion viewing the photo. As for the illustration, that's what it is. FORD published lots of illustrations of cars which never existed (and I can't come to any conclusion on the illustration, regardless).
I am in the process of repairing and fitting rear fenders on a '23 Runabout and I expect that when done, a photo taken from the same distance and angle will produce a very similar unhelpful (at least for me) photo.
That said, I am pretty sure that any combination of parts which will fit, were used occasionally in the factory as the need arose. I would even support the likelihood that some cars came off the line with completely mismatched fenders on some rare occasions and I believe that it's been documented on the forum or at least the belief has been posited and an argument was made to support that view.
As far as the OPs reproduction fenders both being marked for the roadster, well, I believe that is simply an error on the person's part who wrote the information down and that is very common in the world of reproductions...it might even represent the official view of the reproducer...but from an accepted and documented history of FORD parts and known parts catalogues, they were wrong.
NH Full Flow Float Valves
namdc3
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Mon Aug 02, 2021 5:59 pm
Scott, my understanding of the T-8850 and T8851 fenders is that they didn't have the lateral bump out at the rear of the running board. This bump out is seen on at least the front three cars.
Post by Scott_Conger » Mon Aug 02, 2021 6:37 pm
Nikolaus
indeed it is visible. I was not looking for the bumpout, but the solid skirt or not. My apologies...my understanding of your post was wrong, and I was in error in my response to you.
namdc3
Last Name: Martin
MTFCA Number: 32342
MTFCI Number: 23512
Post by namdc3 » Mon Aug 02, 2021 7:20 pm
Scott, not a problem; thanks.
