NORS 1924-25 Rdst-Coupe Fender.
Topic author - Posts: 823
- First Name: Robert
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 1914 tr, 1916 rdts, 1921 tr, 1923 rdst, 1925 cp. 1927 pu, 1927 tr.
- MTFCA Number: 26652
For sale unused NORS 1924-25 left rear fender for a coupe- roadster. This is a hi-quality older heavy repo. New ones are $465. I will take $150. No texting. Call 507 458 6778. S. Mn.
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: NORS 1924-25 Rdst-Coupe Fender.
Would be coupe only. The roadster used the same fender as the touring.
1920 Dodge touring
1920 Dodge touring
They are stamped coupe and roadster but I think you are right. So let us say 1924-25 Coupe.
- MTFCA Number: 14972
- MTFCI Number: 15411
There is documentation here in the Encyclopedia & other documentation supporting the fact that the Runabout did utilize the full skirt rear fender same as the Coupe in 1925 - I had a late production '25 Runabout with the full skirt rear fenders.
- MTFCA Number: 121
- MTFCI Number: 16310
Don Skille has an early '25 roadster with the coupe fenders. They appear to have always have been on the car.
- First Name: DAN
- Last Name: MCEACHERN
Larry- question- So if someone had them on a coupe, would you say that the coupe had roadster fenders on it?
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- MTFCA Number: 23703
- MTFCI Number: 23153
- Board Member Since: 2009
Good question Dan Larry will probably come up with a good answer.
Funny Dan !!!
Missed you & Mary on the Spokane Tour !
- First Name: Nikolaus
- Last Name: Martin
- MTFCA Number: 32342
- MTFCI Number: 23512
Here's two not great data points, but food for thought. This Ford advertisement artist's rendition and these photographed runabouts appear to have the 8850B/8851B rear fenders.
- * REQUIRED* Type and Year of Model Ts owned: '13, '15, '19, '23
Nikolaus
your eyes are better than mine. I can come to no such conclusion viewing the photo. As for the illustration, that's what it is. FORD published lots of illustrations of cars which never existed (and I can't come to any conclusion on the illustration, regardless).
I am in the process of repairing and fitting rear fenders on a '23 Runabout and I expect that when done, a photo taken from the same distance and angle will produce a very similar unhelpful (at least for me) photo.
That said, I am pretty sure that any combination of parts which will fit, were used occasionally in the factory as the need arose. I would even support the likelihood that some cars came off the line with completely mismatched fenders on some rare occasions and I believe that it's been documented on the forum or at least the belief has been posited and an argument was made to support that view.
As far as the OPs reproduction fenders both being marked for the roadster, well, I believe that is simply an error on the person's part who wrote the information down and that is very common in the world of reproductions...it might even represent the official view of the reproducer...but from an accepted and documented history of FORD parts and known parts catalogues, they were wrong.
NH Full Flow Float Valves
- Last Name: Martin
Scott, my understanding of the T-8850 and T8851 fenders is that they didn't have the lateral bump out at the rear of the running board. This bump out is seen on at least the front three cars.
Nikolaus
indeed it is visible. I was not looking for the bumpout, but the solid skirt or not. My apologies...my understanding of your post was wrong, and I was in error in my response to you.
- Last Name: Martin
Scott, not a problem; thanks.
