WTT - Pair of 1 3/8ths Winfield Model 5H carbs for...
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sun Aug 01, 2021 3:02 pm
well, what I really need is a useable A crank converted T engine (long block) year not important...lets make a deal...or Looking for a complete runnable Model N ~ 1 3/4" or so or $1,200 for the pair.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: WTT - Pair of 1 3/8ths Winfield Model 5H carbs for...
Post by Kevin Pharis » Sun Aug 01, 2021 4:54 pm
As I recall... the model “N” carbs were only produced in 2”+ barrel sizes...
I will dig up my catalog to confirm
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Aug 01, 2021 5:09 pm
Correction... looks like it was 1-3/4”, 1-7/8”, and 2”
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sun Aug 01, 2021 6:09 pm
Thank you for the information Kevin, did not know that!
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Sun Aug 01, 2021 6:37 pm
The Model N can be sleeved down, here is an early (not for sale) 2 inch N sleeved down to 1 1/2 inch.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Aug 01, 2021 6:45 pm
Have a complete short block "Stoker" Skat Crank ready for assembly. Cross drilled, A rods, correct pistons and rings, flat top, (T bore to A rods). $5,000.00 you pick up and assemble at your leisure.
All the Best,
Hank
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Aug 01, 2021 8:13 pm
Hey there Mike, thanks for showing that model N. What’s the story on the reducing sleeve...? Was it done to repair a broken throttle housing...?
Oh yeah, nice lookin velocity stack 😉
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sun Aug 01, 2021 9:09 pm
Thank you Hank, that is exactly what I am doing to myself right now with my current build. Hoping that someone has a long block and some other bits they finished 40 or 50 years back sitting in a corner, and a pair of 5H's are just what would make their collection a bit more complete and I can get a jump. ;)
All the Best,
Hank
Jack Tarlinton
First Name: Jack
Last Name: Tarlinton
* REQUIRED* Type and Year of Model Ts owned: 1927 Cut off
Post by Jack Tarlinton » Sun Aug 01, 2021 10:43 pm
If your trade is unsuccessful, I'm interested in buying one 5-H. Are either of yours operable?
Best regards
Jack
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Tue Aug 03, 2021 10:52 am
Good day Jack, hadn't planned on breaking up a pair, H's are rare as Winfield's go, and good pair is even more so.
Yes, these are in nice shape, barrels are tight with limited play, have all the little fiddly brass parts that are always beat up or gone, even have the float bowl caps.
Best regards
Jack
Jack Tarlinton
First Name: Jack
Post by Jack Tarlinton » Tue Aug 03, 2021 8:57 pm
Well, if you do end up stuck with the pair and get tempted to let one of them go, please let me know!
Thanks Douglas
Best regards
Jack
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Thu Aug 05, 2021 7:50 pm
Bumpity bump bump.
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Fri Aug 06, 2021 9:35 am
Have a home for one, 600.00 for the other.
